How to get position of dimension value?
ngdnam88
ngdnam88
Dears,
Is there any solution that can get the position of dimension value?
I'm trying check it in center between dimension lines or not.
Please help me! Thanks!
A.Acheson
Hi @ngdnam88
There is a function to put the  dimension in the center. See help page here
Syntax
LinearGeneralDimension.CenterText()
Regards
Alan
ngdnam88
Thanks @A.Acheson
But I wanna check some dimensions are in center already or not before recenter them. Is it possible to do?
A.Acheson
Not as I can see. The function just centers the dim regardless of its origional position.
Regards
Alan
Stakin
try:
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oLdim As LinearGeneralDimension
oLdim = oDoc.ActiveSheet.DrawingDimensions.Item(1)
Dim oLs2d As LineSegment2d
oLs2d = oLdim.DimensionLine
MessageBox.Show(oLs2d.MidPoint.X & "," & oLs2d.MidPoint.Y, "Dimension Line Center Point")
MessageBox.Show(oLdim.Text.Origin.X & "," & oLdim.Text.Origin.Y, "Dimension Text Point")
oLdim.CenterText
