Need to set multi-value parameter back to default
Inventor 2011
So I'm using a parameter to launch an excel file that this specific Assembly references.  It's not embedded.
I need the ability to launch the referenced excel file.  I have a parameter called "Launch_Excel" with No and Yes as options.
I need to write it such that, if it detects "Yes", that it launches Excel, and also sets that value back to "No".  I can't seem to get it to make this change while the parameter window is open.  Do I need to force Inventor to close the parameter window?
Current code:
Format:HTML Format
Version:1.0
StartHTML: 165
EndHTML: 4650
StartFragment: 314
EndFragment: 4618
StartSelection: 314
EndSelection: 314
If Launch_Excel = "Yes" Then
Launch_Excel = "No"
Dim sheetName As String = ring_size
newExcelApp = CreateObject("Excel.Application")
newExcelApp.Visible = True
wb = newExcelApp.Workbooks.Open(IO.Path.Combine("X:\Autodesk\EVR Inventor Reference Files\", "retaining_ring_specs.xlsm"))
wb.Sheets(sheetName).Activate
End If
MjDeck
While you are editing the "Launch_Excel" parameter, the parameters dialog will not show value changes to it that are made by the rule.  It only shows the changes that you make directly to the cell. This is the way the multi-value list editing control (ComboBox) works within the table of parameters.  I will see if we can change it.
 The way it is now, if you click in another cell in the parameters dialog, you will see that the Launch_Excel value has changed back to Yes.
Mike Deck
Software Developer
Autodesk, Inc.
Ok... makes sense.
Now, would it be possible to:
open parameters, click "yes" from multi-value to launch excel file.
Clicking Yes causes:
If param="Yes" then
-close parameter window
-set param back to "No"
-open parameter window
-launch excel file
MjDeck
Here's a modified version of your rule to do those steps:
Dim oControlDef as ControlDefinition  = ThisApplication.CommandManager.ControlDefinitions.Item("AppSelectNorthwestArrowCmd")
oControlDef.Execute  ' start the default command (Select)
Launch_Excel = "No"
RuleParametersOutput() ' assign the modified value to the parameter right away
oControlDef  = ThisApplication.CommandManager.ControlDefinitions.Item("AppParametersCmd")
oControlDef.Execute ' start the Parameters command
End If
Mike Deck
Software Developer
Autodesk, Inc.
Awesome!  Works perfectly!   Smiley Happy
