Need something like an .IsIsolated property
HogueOne
HogueOne
I'm making something like iCopy that's more suitable for me. In the following code, I add an component to the active document. what I need to do is add the component to the subassembly occurrence that is currently isolated in the active document (double clicked to edit in context). the rule will be running in the subassembly occurrence. Any ideas?
Sub Main()
    ' Get the active document (must be an assembly)
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    ' Ensure the active document is an assembly
    If oAsmDoc.DocumentType <> kAssemblyDocumentObject Then
        MessageBox.Show("Please open an assembly document.", "Error")
        Return
    End If
    ' Present a File Selection dialog
    Dim oFileDlg As Inventor.FileDialog = Nothing
    ThisApplication.CreateFileDialog(oFileDlg)
    oFileDlg.InitialDirectory = "C:\" ' Set your initial directory here
    oFileDlg.Filter = "Inventor Files (*.ipt; *.iam)|*.ipt; *.iam|All Files (*.*)|*.*"
    oFileDlg.DialogTitle = "Select a file to insert as an occurrence"
    oFileDlg.CancelError = True
    On Error Resume Next
    oFileDlg.ShowOpen()
    If Err.Number <> 0 Then
        MessageBox.Show("File selection canceled.", "Error")
        Return
    ElseIf oFileDlg.FileName = "" Then
        MessageBox.Show("No file selected.", "Error")
        Return
    End If
    On Error GoTo 0
    Dim originalFile As String = oFileDlg.FileName
    Dim newFile As String = CreateCopyWithIncrementedName(originalFile)
    If newFile = "" Then
        MessageBox.Show("Failed to create a copy of the file.", "Error")
        Return
    End If
    ' Add the new file as an occurrence in the active assembly
    Dim oOccurrence As ComponentOccurrence
    oOccurrence = oAsmDoc.ComponentDefinition.Occurrences.Add(newFile, ThisApplication.TransientGeometry.CreateMatrix())
    ' Ensure the occurrence was added successfully
    If oOccurrence Is Nothing Then
        MessageBox.Show("Failed to add the selected file as an occurrence.", "Error")
        Return
    End If
    ' Make the occurrence adaptive
    oOccurrence.Adaptive = True
    ' Prompt the user to select a plane in the assembly
    Dim oPlane As Object
    oPlane = ThisApplication.CommandManager.Pick(kWorkPlaneFilter, "Select a plane in the assembly.")
    ' Ensure the user selected a valid plane
    If oPlane Is Nothing Then
        MessageBox.Show("No plane selected.", "Error")
        Return
    End If
    ' Try to get the "PlaneFront" plane from the occurrence
    Dim oOccPlaneFront As WorkPlane
    oOccPlaneFront = oOccurrence.Definition.WorkPlanes.Item("PlaneFront")
    On Error GoTo 0
    ' Check if "PlaneFront" was found
    If oOccPlaneFront Is Nothing Then
        MessageBox.Show("Geometric entity 'PlaneFront' cannot be found. Aborting operation.", "Error")
        Return
    End If
    ' Create a proxy for the occurrence's "PlaneFront" plane
    Dim oOccPlaneFrontProxy As WorkPlaneProxy
    oOccurrence.CreateGeometryProxy(oOccPlaneFront, oOccPlaneFrontProxy)
    ' Create a flush constraint between the selected plane and "PlaneFront"
    Dim oFlushConstraint As FlushConstraint
    oFlushConstraint = oAsmDoc.ComponentDefinition.Constraints.AddFlushConstraint(oPlane, oOccPlaneFrontProxy, 0)
    ' Array to store the four sketch curves
    Dim oSketchCurves(3) As Object
    Dim curveNames As String() = {"Bottom", "Top", "Left", "Right"}
    ' Prompt the user to select four sketch curves in the assembly
    For i As Integer = 0 To 3
        oSketchCurves(i) = ThisApplication.CommandManager.Pick(kSketchCurveFilter, "Select the " & curveNames(i) & " sketch curve in the assembly.")
        ' Ensure the user selected a valid sketch curve
        If oSketchCurves(i) Is Nothing Then
            MessageBox.Show("No sketch curve selected for the " & curveNames(i) & " constraint.", "Error")
            Return
        End If
    Next
    ' Array to store the four axes in the new order
    Dim oOccAxes(3) As WorkAxis
    Dim axisNames As String() = {"AxisBottom", "AxisTop", "AxisLeft", "AxisRight"}
    ' Try to get the axes from the occurrence
        oOccAxes(i) = oOccurrence.Definition.WorkAxes.Item(axisNames(i))
        On Error GoTo 0
        ' Check if the axis was found
        If oOccAxes(i) Is Nothing Then
            MessageBox.Show("Geometric entity '" & axisNames(i) & "' cannot be found. Aborting operation.", "Error")
            Return
        End If
    Next
    ' Create proxies for the occurrence's axes and add mate constraints
    Dim oConstraints(3) As MateConstraint
        Dim oOccAxisProxy As WorkAxisProxy
        oOccurrence.CreateGeometryProxy(oOccAxes(i), oOccAxisProxy)
        oConstraints(i) = oAsmDoc.ComponentDefinition.Constraints.AddMateConstraint(oSketchCurves(i), oOccAxisProxy, 0)
    Next
    ' Notify the user of success
    MessageBox.Show("Adaptive occurrence added and constrained successfully.", "Success")
End Sub
Function CreateCopyWithIncrementedName(originalFile As String) As String
    Dim fso As Object
    fso = CreateObject("Scripting.FileSystemObject")
    Dim folder As String = fso.GetParentFolderName(originalFile)
    Dim baseName As String = fso.GetBaseName(originalFile)
    Dim extension As String = fso.GetExtensionName(originalFile)
    Dim counter As Integer = 1
    Do
        newFile = folder & "\" & baseName & "-" & Right("000" & counter, 3) & "." & extension
        counter = counter + 1
    Loop While fso.FileExists(newFile)
    ' Copy the file
    fso.CopyFile(originalFile, newFile)
    ' Return the new file path if successful
    If fso.FileExists(newFile) Then
        Return newFile
    Else
        Return ""
    End If
End Function
WCrihfield
Hi @HogueOne.  If you need to specifically and directly access the Document object that you are in 'edit mode' of within an assembly, then you can use the 'ThisApplication.ActiveEditDocument' property.  That was specifically designed for situations like that.  The 'ThisApplication.ActiveDocument' property will always point to the main assembly, when you were editing an assembly when the code started.  If you are editing a component within a component, within an assembly (3 levels deep, but started from the main assembly), then the above statements will still be true, but ActiveEditDocument will be the first level component that is being edited, not the second level component.  In that case, you can additionally use the ThisApplication.ActiveEditObject property.  Its value may not be a Document though.  If you are editing a sketch, it will return that sketch, or if you are editing the 'FlatPattern' portion of a sheet metal part, it will return that FlatPattern object (a variation of ComponentDefinition), and so on.  Just a couple tips that may help in those types of situations.
Edit:  Also, in iLogic rules (and vb.net in general), if you will be getting or setting a value that is supposed to be a variation of an 'Enum', and you are working with the 'name' of the enum variation (instead of its numeric value), then you should always specify the name of the enum itself, before the name of the enum variation.
For example, instead of this:
...it should be like this:
If oAsmDoc.DocumentType <> DocumumentTypeEnum.kAssemblyDocumentObject Then
and also instead of this:
... = ThisApplication.CommandManager.Pick(kSketchCurveFilter, ...
... it should be like this:
... = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveFilter, ...
When writing code in the old VBA system, it encourages you to exclude the name of the enum, but in the newer vb.net system, they instruct us to include its name.  In iLogic rules, when you start with the name of the Enum, then type the dot after that, it will show the list of all its variations for you to choose from.  There will usually be a hint about the expected Type in a small pop-up hint, and that usually shows us the name of the Enum, so we can type it in.  This is not always a critical issue, but sometimes it makes all the difference.
Wesley Crihfield
(Not an Autodesk Employee)
