- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I may have just been looking at this to long, but could use some help figuring it out.I have a full model (Assembly, Subassemblies , parts) That needs to grow upwards. My full model does this great. I put an overall height in and it is spot on. My real model is in feet with some things being supressesed for various reasons. As i can't upload the real model due to IP i have done a test model to demenstrate. It also works great so far,
My problem is if Standard =False i need the pattern to add a section, the plane to move up to this section and my part 5 subtract the difference so that the assembly total height = OA height.
Right now if i put 151.625 in the model will adjust to that height , but it leaves a gap between part 5 and the pattern. I need the pattern and Plane1 to round up to the nearest multiple of 20 ( this would make the model 161.625 In height) Then i need part 5 to shrink to make the Assembly 151.625 tall.
So trying to get it to round up or down to the nearest multiple of 20 is where my problem is.
Hope it all makes sense and the test model is uploaded so play away.
