Need some codes to auto-fill the boxes in the Assembly form
Christy.Tuan
Christy.Tuan
Hi, everyone! I created a form for the Assembly, but it takes time to fill the boxes with each part's name (ex. put M5765-CH:1 into MENEAUX_GAUCHE box). Is there is a better way to do it? For example, I click the box of MENEAUX_GAUCHE, and then I click the part in the Model list M5765-CH:1. The system can automatically copy the name M5765-CH:1  into the box. I hope there is a way to do it. Thanks !!!
A.Acheson
Could you explain in some more detail the work flow you want to carry out? Do you want to populate a single  iproperty of the part  to the assembly or are you wanting to update the part iproperties etc.
Because of the user interaction and use of forms we will need to know the whole workflow. The use of a global form might be helpful too depending on your over all goal.
Regards
Alan
