Need moving a sketch using iLogic - Pl. help.
I have a sketch that I want to move up and down according to the +ve or -ve value of the elevation parameter. My iLogic I created is not doing well: i.e., if I assign a new different value (using the User Parameter table) for the parameter "RelativeElevation" to say +12, it works. Next time if I change the same parameter to -12, by choosing the right click menu for "Run Rule" the iLogic doesn't move the sketch (down in this case). However, if I open the iLogic and click OK it runs. It doesn't run (change the elevation) at the first time. I request some one to help me. Sketch and iLogic text files are attached here to for information, pl.
Vladimir.Ananyev
If you still have no solution then please upload the test model with your iLogic rule.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
