Message 1 of 1
NEED iLOGIC HELP TO HIDE/UNHIDE IN A PATTERN AND CHG TO DEFAULT/REF
Allow a simple control in iLogic that can turn off or on vis in a folder even when parts are in a pattern. I cannot seem to come up with a simple solution to use a true/false parameter controlled by a check box using iLogic and folders with the parts that need to turn on/off vis and check parts to default and reference in the Bom Structure when the parts in the folders need to be patterned. The pattern is 1 or 2 and has few elements.
