Need help with adding suffix characters to custom part number field
kwilson_design
kwilson_design
Hey everyone,
Trying to get some help with creating iLogic to populate a custom iproperty field called “Finished part number”. The finished part number is just a suffix of “-N” at the end of the standard part number.
Example:
part number iproperty: 123-456789
Finished part number custom iproperty: 123-456789-N
Kenny
If this post solved your issue please mark "Accept as Solution". It helps everyone...really!
JelteDeJong
I guess it is as simple as this but maybe I did not get the question.
iProperties.Value("Custom", "Finished part number") = iProperties.Value("Project", "Part Number") & "-N"
Jelte de Jong
Blog: hjalte.nl - github.com
kwilson_design
Geez not sure why I didn't think of it being that simple. It's late in the day and I'm still somewhat new to learning ilogic. Exactly what I need and thanks a lot!
Kenny
kwilson_design
Is it possible to create a variable or "If, then" statement so that it only runs this code if my part number begins with "PS"? We have multiple part numbering schemes and I only want to ad the "-N" suffix to files that begin with "PS" as the first 2 characters in the part number iproperty.
For example we may have a part number called PS123-45678, which I would want to add the -N suffix for my Finished Part Number custom iprop. However we may also have a part number called U555-55555 which I would not want to run then rule on to populate the -N. trying to keep users from having to decided when to suppress rules.
Any help would be greatly appreciated!
Kenny
