How do I change ALL the material properties for PARTS at the ASSEMBLY level?
gavin.allenHSSRX
Message 1 of 19
gavin.allenHSSRX
I have a little bit of code and being a novice, complete beginner, cannot understand what is wrong. Please can someone help.
    Sub Main()
        Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
        Dim oOccurrence As ComponentOccurrence
        ' Get the material name to apply to all components
        Dim materialName As String = "Stainless Steel"
        ' Iterate through each component occurrence in the assembly
        For Each oOccurrence In oAsmDoc.ComponentDefinition.Occurrences
            ' Check if the component has a PartDocument
            If TypeOf oOccurrence.Definition.Document Is PartDocument Then
                Dim oPartDoc As PartDocument = oOccurrence.Definition.Document
                Dim currentMaterialName As String = oPartDoc.ComponentDefinition.Material.Name
                If currentMaterialName = materialName Then
                    ' Set the material for the component occurrence
                    oPartDoc.ComponentDefinition.Material.SetMaterial(materialName)
        Next
        ' Save the changes
        oAsmDoc.Save()
    End Sub
Regards
K.I.S.S. (keep it simple stupid)
Life doesn't have to be complicated.
Designs don't have to be complicated.
GOD Bless you.
Replies (18)
Message 2 of 19
Andrii_Humeniuk
Hi @gavin.allenHSSRX . I modified your code a bit. Please check if everything works as you wanted.
Sub Main()
	Dim oAssetlib As AssetLibrary
	Dim oAsset As Asset
	For Each oAssetlib In ThisApplication.AssetLibraries
		For i As Integer = 1 To oAssetlib.MaterialAssets.Count
			If oAssetlib.MaterialAssets.Item(i).DisplayName = materialName Then
				oAsset = oAssetlib.MaterialAssets.Item(i)
				GoTo NextStep
		Next
	Next
	NextStep :
	If oAsset Is nothiong Then Exit Sub
			If oPartDoc.IsModifiable Then
				Dim currentMaterialName As String = oPartDoc.ActiveMaterial.DisplayName
				If Not String.IsNullOrEmpty(currentMaterialName) Then
					If currentMaterialName <> oAsset.DisplayName Then
						oPartDoc.ActiveMaterial = oAsset
	Next
	' Save the changes
	oAsmDoc.Update()
	oAsmDoc.Save()
End Sub
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 3 of 19
gavin.allenHSSRX
Thank you so much, this has rune without any erros.
GOD Bless you.
Message 4 of 19
romu51
I Like this one.... now added to my list.
it will work as long as the material exists in the library.
it also changed my content centre part i had in my assembly.
I tried to supress the components i didn't want to change by supressing them  before i ran the rule but it gave me an error.
is there an easy way to omit the CC parts?
Message 5 of 19
Andrii_Humeniuk
Hi @romu51 . Try this code:
Sub Main()
	Dim oTM As TransactionManager = ThisApplication.TransactionManager
	Dim oAsset As Asset
				GoTo NextStep
		Next
	Next
	NextStep :
	Dim newTM As Transaction = oTM.StartTransaction(oAsmDoc, "ChangeMaterial")
	Dim strLocName, strLocType, currentMaterialName As String
		If Not oOccurrence.Suppressed Then
					oPartDoc.GetLocationFoundIn(strLocName, strLocType)
					If Not strLocType = kLibraryLocation Then
						currentMaterialName = oPartDoc.ActiveMaterial.DisplayName
	Next
	newTM.End()
	' Save the changes
	oAsmDoc.Update()
	oAsmDoc.Save()
End Sub
Message 6 of 19
romu51
@Andrii_Humeniuk
That works fine!
Many thanks!
I'll probably start a new thread to make this one evolve a bit more.
Message 7 of 19
ch_giacomo
hello good rule.
would it be possible to modify it so that not all the components are modified but only those that you want with the click of the mouse?
Do you think it is possible?
Message 8 of 19
MichaëlStienstra
Some small arrangements on the code. It will let you chose out of an material list instead of only "Stainless Steel". It could be written smaller, but I used some code form an older project of mine.
Sub Main()
	'Arraylist selection
	'Lijst labels
	Dim oSearchlabel As New ArrayList
	oSearchlabel.Add("Stainless Steel")
	oSearchlabel.Add("Steel")
	oSearchlabel.Add("Rubber")
	oSearchlabel.Add("ABS Plastic")
	oSearchlabel.Add("Aluminium 6061")
	oSearchlabel.Add("Concrete")
	oSearchlabel.Add("Generic")
	oSearchlabel.Add("Polythylene High Density")
	oSearchlabel.Add("Polythylene Low Density")
	oSearchlabel.Add("")
	oSearchlabel.Add("Custom Google search")
	'Basis lijst
	A1 = InputListBox("", oSearchlabel, oSearchlabel, Title := "Materials", ListName := "Material list")
	If A1 = "Stainless Steel" Then
		B1 = "Stainless Steel"
	If A1 = "Steel" Then
		B1 = "Steel"
	If A1= "Rubber" Then
		B1 = "Rubber"
	If A1 = "ABS Plastic" Then
		B1 = "ABS Plastic"
	If A1 = "Aluminium 6061" Then
		B1 = "Aluminium 6061"
	If A1 = "Concrete" Then
		B1 = "Concrete"
	If A1 = "Generic" Then
		B1 = "Generic"
	If A1 = "Polythylene High Density" Then
		B1 = "Polythylene High Density"
	If A1 = "Polythylene Low Density" Then
		B1 = "Polythylene Low Density"
	Dim materialName As String = B1
	Dim oAsset As Asset
				GoTo NextStep
		Next
	Next
	NextStep :
	Next
	newTM.End()
	' Save the changes
	oAsmDoc.Update()
	oAsmDoc.Save()
End Sub
Message 9 of 19
Andrii_Humeniuk
Hi @ch_giacomo . There are several options for solving this task:
  • Create an Array() in code with a list of your components, but this list needs to be constantly edited.
  • Add a MessageBox to the code that on each component will ask you if the code can change the material, but it's much more than one click.
Message 10 of 19
ch_giacomo
Sorry but I'm not good at programming.
I was thinking something like this: ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select a part in the assembly")
this is a copy and paste of another rule I just don't know how to adapt it to this one.
Do you think it is correct to start from this idea?
Message 11 of 19
ch_giacomo
Thanks, I'll take that into consideration
Message 12 of 19
Andrii_Humeniuk
No problem. This code changes the material for one or more selected components. You need to select the components before running the code.
Sub Main()
	Dim oSS As SelectSet = oAsmDoc.SelectSet
	If oSS.Count = 0 Then
		MessageBox.Show("You have not selected components.", "Error!",MessageBoxButtons.OK,MessageBoxIcon.Error)
		Exit Sub
	Dim oAsset As Asset
				GoTo NextStep
		Next
	Next
	NextStep :
	For i As Integer = 1 To oSS.Count
		If oSS.Item(i).Type = ObjectTypeEnum.kComponentOccurrenceObject Then
			oOccurrence = oSS.Item(i)
	Next i
	newTM.End()
	oAsmDoc.Update()
'	oAsmDoc.Save()
End Sub
Message 13 of 19
MichaëlStienstra
Arrangement of @Andrii_Humeniuk code. As before I've added the possibility to chose different materials. It could be written smaller, but I used some code form an older project of mine.
Sub Main()
		Exit Sub
	'Lijst labels
	oSearchlabel.Add("Custom")
	'Basis lijst
	A1 = InputListBox("", oSearchlabel, oSearchlabel, Title := "Title", ListName := "Material list")
		B1 = "Steel"
		B1 = "Rubber"
		B1 = "ABS Plastic"
		B1 = "Concrete"
		B1 = "Generic"
	'Dim materialName As String = "Stainless Steel"
	Dim oAsset As Asset
				GoTo NextStep
		Next
	Next
	NextStep :
	Next i
	newTM.End()
	oAsmDoc.Update()
'	oAsmDoc.Save()
End Sub
Message 14 of 19
ch_giacomo
Thank you for your time.
It gives me the error:
System.ArgumentException: Incorrect parameter. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.SelectSet.get_Item(Int32 Index)
in ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
the first part is changed then the process seems to hang
Message 15 of 19
Andrii_Humeniuk
Sorry, I made a mistake, try this code:
Sub Main()
		Exit Sub
	Dim oOccsList As New List(Of ComponentOccurrence)
	Dim oAsset As Asset
				GoTo NextStep
		Next
	Next
	NextStep :
			oOccsList.Add(oSS.Item(i))
	Next i
	For i As Integer = 0 To oOccsList.Count -1
		oOccurrence = oOccsList.Item(i)
	Next i
	newTM.End()
	oAsmDoc.Update()
'	oAsmDoc.Save()
End Sub
Message 16 of 19
ch_giacomo
WOW super.
thank you so much.
For us who know little about programming it is a lot of work saved in everyday comfort.
Message 17 of 19
ch_giacomo
good morning, could you modify the rule so that you can start the rule and after selecting the components you want to change the material? Thank you
Message 18 of 19
ch_giacomo
Hi everyone, I did a bit of research and came up with this rule, I'll post it if anyone needs it.
The rule makes you choose the material from a list and then you can select the parts of an assembly, to exit press ESC.
change this line to your materials
Dim materials As String() = {"Material1","Material2","Material3", "Material4", "Material5", "Material6", "Material7", "Material8", "Material9"}
' Default list of materials
' Creation of the material selection dialog
Dim selectedMaterial As String
selectedMaterial = InputListBox("Select material:", materials)
' Check if the selected material is valid
If selectedMaterial = "" Then
     Call MsgBox("No material selected.", vbCritical, "iLogic")
     Exit Sub
Dim App As Inventor.Application = ThisApplication
If Not ThisDoc.Document.DocumentType = kAssemblyDocumentObject Then
     Call MsgBox("Only in assemblies", vbCritical, "iLogic")
     Exit Sub
Dim oAssDoc As AssemblyDocument = ThisDoc.Document
Dim bStop As Boolean = False
Dim oSel As Object
Do While bStop = False
     oSel = oApp.CommandManager.Pick(kAssemblyLeafOccurrenceFilter, "Select part (End with Esc)")
     If oSel Is Nothing Then
         bStop = True
     Else
         If oSel.Type = kComponentOccurrenceObject OrElse oSel.Type = kComponentOccurrenceProxyObject Then
             Dim oPartDoc As PartDocument = oSel.Definition.Document
             ' Search for the material in the document's asset list
             Dim oMatAsset As MaterialAsset
             For Each oMatAsset In oPartDoc.MaterialAssets
                 If oMatAsset.DisplayName = selectedMaterial Then
                     Exit For
                 Else
                     oMatAsset = Nothing
             Next
             ' If the material is not present in the document, search the active asset library
             If oMatAsset Is Nothing Then
                 Dim oAssetLib As AssetLibrary = oApp.ActiveMaterialLibrary
                 Dim oLibAsset As MaterialAsset
                 For Each oLibAsset In oAssetLib.MaterialAssets
                     If oLibAsset.DisplayName = selectedMaterial Then
                         oMatAsset = oLibAsset.CopyTo(oPartDoc)
                         Exit For
                 Next
             ' If the material is not yet found, show an error message
                 Call MsgBox("Material " & selectedMaterial & " not found.", vbCritical, "iLogic")
                 Exit Sub
             ' Set the active material in the document
             oPartDoc.ActiveMaterial = oMatAsset
             ' Update the active document
             Call oApp.ActiveDocument.Update
Loops
Message 19 of 19
Support_Charlies3DT
@gavin.allenHSSRX We have an app that can change the material and a lot of properties of all parts inside an assembly. If you are interested we can send you a test installer and you can have a look at the app. You can send me a pm if interested.
