Need C# Help in BrowserPanesEvents
I would appreciate any sample code on BrowserPanesEvents in C#.
VB.Net would probably be ok too.
Luc
Here is what I wrote so far:
private Inventor.BrowserPanesSink_OnBrowserNodeActivateEventHandler oBrowserNodeActivateHandler;
public void OnBrowserNodeActivate( Object BrowserNodeDefinition, NameValueMap Context, out HandlingCodeEnum kHandlingCode)
kHandlingCode = HandlingCodeEnum.kEventNotHandled;
oPanes= oDoc.BrowserPanes;
if (oPanes!=null)
oBrowserNodeActivateHandler = new Inventor.BrowserPanesSink_OnBrowserNodeActivateEventHandler(OnBrowserNodeActivate);
oPanes.BrowserPanesEvents.OnBrowserNodeActivate += oBrowserNodeActivateHandler;
when I put a break point on oBrowserNodeActivateHandler, it never hits when I click on my browser nodes.
I must be missing something trivial.
thanks,
Luc
Ok, it works.
I did not know that to activate a node you have to double click it!
As I implemented the other events it became obvious they were working and by double clicking I finally hit my breakpoint!
On to the next hurdle...
Luc
I've got the problem with handling inventor events in standalone VB.Net application.
While OnSaveDocument, OnActivateDocument, ... work fine, the events for BrowserPanes don't.
Here is my code:
Public Class Form1
Public invApp As Inventor.Application
Public appEvents As Inventor.ApplicationEvents
Public  bPanesEvents As Inventor.BrowserPanesEvents
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Call Inventor_connection()
appEvents = invApp.ApplicationEvents
AddHandler appEvents.OnSaveDocument, AddressOf Me.appEvents_OnSaveDocument
AddHandler appEvents.OnActivateDocument, AddressOf Me.appEvents_OnActivateDocument
activeDoc = invApp.ActiveDocument
bPanesEvents = activeDoc.BrowserPanes.BrowserPanesEvents
AddHandler bPanesEvents.OnBrowserNodeActivate, AddressOf Me.bPanesEvents_OnBrowserNodeActivated
End Sub
Public Sub appEvents_OnSaveDocument(ByVal docObject As Inventor._Document, _
ByVal b_or_a As Inventor.EventTimingEnum, _
ByVal context As Inventor.NameValueMap, _
ByRef handlingCode As Inventor.HandlingCodeEnum)
If b_or_a = EventTimingEnum.kAfter Then
MsgBox("Document saved!!")
End If
End Sub
Public Sub appEvents_OnActivateDocument(ByVal docObject As Inventor._Document, _
MsgBox("Document activated!!")
End If
End Sub
Public Sub bPanesEvents_OnBrowserNodeActivated(ByVal browserNodeDef As Object, _
MsgBox("Browser node activated!!")
End Sub
End Class
Please help me.
Thx!
