Named Entities
Named Entities
ndillner343SKL
Named Entities
ndillner343SKL
I don't know if this is possible or not. But I'm trying to identify named entities. I'm able to grab the entities I need from the constraints at the assembly level "oEnt1" & "oEnt2". Now I'm trying to look at those entities and determine what their names are. "Face0" for example. Then if they don't have names, assign them names.
		Dim oEnt1 As Object = oConst.EntityOne
		Dim oEnt2 As Object = oConst.EntityTwo
WCrihfield
Hi @ndillner343SKL.  Yes, that is possible, but it can be fairly complicated behind the scenes.  I actually created a custom function some time back just for retrieving assigned names from various possible objects that may have been assigned a name using the built-in NamedEntities interface.  The entities you will get from the EntityOne or EntityTwo of an assembly constraint will almost always be a proxy of some sort, that only exists within the context of the assembly, so they won't have the name assigned directly to them.  The name will be assigned to the 'native' object that the proxy was a copy of (the actual geometry within the context of a part).  Of course it is possible that one side of your constraint was to one of the assemblies own work features, in which case it will not be a proxy though.  Either way, you can feed the object you get from that EntityOne to this function, and the function will either return its name, or an empty String.  You would just have to check the returned value to make sure it is not empty, before trying to use it for anything important.
Keep in mind, to use this function, your other iLogic rule code would need to be within the Sub Main...End Sub boundaries, then this whole function below, would be placed below the End Sub somewhere.  Then somewhere within your Sub Main area, you just need to declare a String type variable and set its value by calling this function to run, and put that object as its input variable.
Here is that function's code:
Function GetEntityName(oEntity As Object) As String
	Dim oType As String = TypeName(oEntity)
	Dim oDoc As Document = Nothing
	Dim oFace As Face = Nothing
	Dim oEdge As Edge = Nothing
	Dim oVertex As Vertex = Nothing
	Dim oNativeObject As Object = Nothing
	Select Case oType
	Case "Face"
		oFace = oEntity
		oDoc = oFace.Parent.ComponentDefinition.Document
	Case "FaceProxy"
		Dim oFaceProxy As FaceProxy = oEntity
		If TypeOf oFaceProxy.NativeObject Is FaceProxy Then
			GetEntityName(oFaceProxy.NativeObject)
		Else
			oFace = oFaceProxy.NativeObject
		oNativeObject = oFace
	Case "Edge"
		oEdge = oEntity
		oDoc = oEdge.Parent.ComponentDefinition.Document
	Case "EdgeProxy"
		Dim oEdgeProxy As EdgeProxy = oEntity
		If TypeOf oEdgeProxy.NativeObject Is EdgeProxy Then
			GetEntityName(oEdgeProxy.NativeObject)
		Else
			oEdge = oEdgeProxy.NativeObject
		oNativeObject = oEdge
	Case "Vertex"
		oVertex = oEntity
		oDoc = oVertex.Parent.ComponentDefinition.Document
	Case "VertexProxy"
		Dim oVertexProxy As VertexProxy = oEntity
		If TypeOf oVertexProxy.NativeObject Is VertexProxy Then
			GetEntityName(oVertexProxy.NativeObject)
		Else
			oVertex = oVertexProxy.NativeObject
		oNativeObject = oVertex
	End Select
	If IsNothing(oDoc) Then Return ""
	Dim oNEs As NamedEntities = iLogicVb.Automation.GetNamedEntities(oDoc)
	Dim oName As String
	If IsNothing(oNativeObject) Then
		oName = oNEs.GetName(oEntity)
	Else
		oName = oNEs.GetName(oNativeObject)
	Return oName
End Function
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
Here is a similar custom Sub routine I just created, for attempting to assign a name to an object that might possibly be a proxy in a scenario like that.  This might fail if the input object is a work feature, but work features can be named easily enough through other means.  You might just have to test for what type of object it is ahead of time.  I have not tried using this one yet, because I have not needed to use it before, so try it at your own risk.
Sub AssignNameToEntity(oEntity As Object, oName As String)
	Dim oPDoc As PartDocument = Nothing
	Select Case oType
	Case "Face"
		oFace = oEntity
		oPDoc = oFace.Parent.ComponentDefinition.Document
	Case "FaceProxy"
			AssignNameToEntity(oFaceProxy.NativeObject, oName)
		Else
	Case "Edge"
		oEdge = oEntity
		oPDoc = oEdge.Parent.ComponentDefinition.Document
	Case "EdgeProxy"
			AssignNameToEntity(oEdgeProxy.NativeObject, oName)
		Else
	Case "Vertex"
		oVertex = oEntity
		oPDoc = oVertex.Parent.ComponentDefinition.Document
	Case "VertexProxy"
			AssignNameToEntity(oVertexProxy.NativeObject, oName)
		Else
	End Select
	If IsNothing(oPDoc) Then Exit Sub
	Dim oNEs As NamedEntities = iLogicVb.Automation.GetNamedEntities(oPDoc)
		Try
			oNEs.SetName(oEntity, oName)
		Catch oEx As Exception
			MsgBox("Error trying to set name to supplied entity." & vbCrLf & _
			oEx.Message & vbCrLf & oEx.StackTrace, vbExclamation, "")
			'Logger.Error("Error trying to set name to supplied entity." & vbCrLf & _
			'oEx.Message & vbCrLf & oEx.StackTrace)
		End Try
	Else
		Try
			oNEs.SetName(oNativeObject, oName)
			MsgBox("Error trying to set name to 'native object' of supplied entity." & vbCrLf & _
			'Logger.Error("Error trying to set name to 'native object' of supplied entity." & vbCrLf & _
		End Try
End Sub
Wesley Crihfield
ndillner343SKL
Thank you so much, again @WCrihfield. You're always a huge help!
ndillner343SKL
Hi @WCrihfield
Is there a way to preform this same process but with the source face. I'm working within an assembly and instead of grabbing the assembly level ProxyFace. I'd like to grab the face that's being used to create the proxy face and name it.
I tried having it grab the source face when setting oEnt1 & 2 as Objects. But it doesn't return any value.
Dim oEnt1 As Object = oConst.EntityOne.NativeObject.GetSourceFace
Sub Main
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
	MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "iLogic")
	Exit Sub
	Dim x As Integer = 0
	Dim oADoc As AssemblyDocument = ThisDoc.Document
	Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
	Dim oConsts As AssemblyConstraints = oADef.Constraints
	For Each oConst As AssemblyConstraint In oConsts
		Dim oEnt2 As Object = oConst.EntityTwo.NativeObject.GetSourceFace
		x = x + 1
		oName = "Entity1:" & x
		Call AssignNameToEntity(oEnt1, oName)
		Dim EntityOne As String = GetEntityName(oEnt1)
		MsgBox(EntityOne)
		oName = "Entity2:" & x
		Call AssignNameToEntity(oEnt2, oName)
		Dim EntityTwo As String = GetEntityName(oEnt2)
		MsgBox(EntityTwo)
	Next
End Sub
	Select Case oType
	Case "Face"
		oFace = oEntity
	Case "FaceProxy"
		Else
	Case "Edge"
		oEdge = oEntity
	Case "EdgeProxy"
		Else
	Case "Vertex"
		oVertex = oEntity
	Case "VertexProxy"
		Else
	End Select
	Dim oName As String
	Else
	Return oName
End Function
	Select Case oType
	Case "Face"
		oFace = oEntity
	Case "FaceProxy"
		Else
	Case "Edge"
		oEdge = oEntity
	Case "EdgeProxy"
		Else
	Case "Vertex"
		oVertex = oEntity
	Case "VertexProxy"
		Else
	End Select
		Try
		End Try
	Else
		Try
		End Try
End Sub
WCrihfield
Hi @ndillner343SKL.  Your two lines of code that are attempting to retrieve the 'native' source face may not be returning the face you want, if anything at all.  This can be a tricky situation, because if the constraint is to a face that belongs to a component that is down within one or more sub-assemblies, the 'NativeObject' may still be a 'proxy' type object (the proxy of that face from within the sub-assembly's context).  And I'm not 100% sure if the 'GetSourceFace' method is a good replacement for the NativeObject property for retrieving the true face of the part, because I simply haven't used it much before.
 I designed those two custom routines so that they will 'recursively' dig down to the true source geometry object in the context of a part before they will try to retrieve or set a name, so you should not really need to dig down to the source object before supplying it to either of those two routines.  However, they should still work just fine if you did supply the native/source objects directly to them.
Wesley Crihfield
