n° 2 automatic constrains
TecnicoPanni
Message 1 of 9
TecnicoPanni
Good morning,
I have this macro, which automatically creates a constraint between the axis Z of the assembly and the axis Z of the selected part.
Sub Vincola_AsseZ()
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oComp As ComponentOccurrence
' Get the XY plane from each occurrence. This goes to the
' component definition of the part to get this information.
' This is the same as accessing the part document directly.
' The work plane obtained is in the context of the part,
' not the assembly.
Dim oCompPlane1 As WorkPlane
Dim oCompAxisZ As WorkAxis
' set the axis Z of the active assembly
Dim AsmAxisZ As WorkAxis
Set AsmAxisZ = oAsmCompDef.WorkAxes.Item(3)
selezione:
'reference to the selected dimension
Set oComp = ThisApplication.CommandManager.Pick(kAssemblyOccurrenceFilter, "Seleziona il componente")
'exit sub if is nothing (Esc)
If oComp Is Nothing Then Exit Sub
Set oCompAxisZ = oComp.Definition.WorkAxes.Item(3)
' Because we need the work plane in the context of the assembly
' we need to create proxies for the work planes. The proxies
' represent the work planes in the context of the assembly.
Dim oAsmAxisZ As WorkAxisProxy
Call oComp.CreateGeometryProxy(oCompAxisZ, oAsmAxisZ)
' Create the constraint using the work plane proxies.
Call oAsmCompDef.Constraints.AddMateConstraint(oAsmAxisZ, AsmAxisZ, 0) ' .AddMateConstraint(oAsmPlane1, oAsmPlane2, 0)
'loop selection
GoTo selezione
End Sub
I would like to automatically add a second constraint: angle constrain between the axis Y of the assembly and the YZ plane of the same selected part.
I've tried by myself, but without success...
...does anyone can help me?
Many thanks
Replies (8)
Message 2 of 9
FINET_Laurent
Hi @TecnicoPanni,
What would be the angle value ?
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 3 of 9
TecnicoPanni
as default, 0
Message 4 of 9
dypro
hi @FINET_Laurent @TecnicoPanni
If there is a way to do it, I would be interested as well
Message 5 of 9
m_baczewski
Hello  @TecnicoPanni
Try to use this code, in this code you can insert your own angle in degree. Give feedback if its correct.
Sub Vincola_AsseZ()
Dim angle As Integer
angle = 0
Dim rad As Double
rad = (angle * (4 * Math.Atn(1))) / 180
' not the assembly.
Dim oCompPlaneYZ As WorkPlane
Dim AsmAxisY As WorkAxis
Set AsmAxisY = oAsmCompDef.WorkAxes.Item(2)
selezione:
Set oCompPlaneYZ = oComp.Definition.WorkPlanes.Item(1)
Dim oAsmPlaneYZ As WorkPlaneProxy
Call oComp.CreateGeometryProxy(oCompPlaneYZ, oAsmPlaneYZ)
Call oAsmCompDef.Constraints.AddAngleConstraint(oAsmPlaneYZ, AsmAxisY, rad)
'loop selection
GoTo selezione
End Sub
Message 6 of 9
dypro
hello @m_baczewski
I'm trying to use the code as well but in my case is in ilogic
I have deleted the "set" and the previous version of the code worked, but for some reason I get an error in this line:
 "Atn" is not a member of "System.Math"
Is there anyway to make it work in my case?
Message 7 of 9
m_baczewski
Hello @dypro
You sholud change this line of code to looks like:
rad = (angle * Math.PI) / 180
Message 8 of 9
dypro
Thanks @m_baczewski
I just changed the
to
rad = (angle * (4 * Math.Atan(1))) / 180
 and it worked well so thankyou
Message 9 of 9
m_baczewski
I'm glad you managed to solve this problem.
