iLogic drawing - Component.IsActive
m_baczewski
m_baczewski
Is it possible to use phrase Component.IsActive in drawing? I`m trying to add balloons while component is active but cant to do it because i getting error "Component: This function can only be used within the scope of a assembly."
Dont want to use try catch its cost to much time and dont want go through API.
Do you know clever solution?
MjDeck
You can do it in Inventor 2021 and later.
Here's sample code:
Dim modelDoc = ThisDrawing.ModelDocument
Dim modelObjects = StandardObjectFactory.Create(modelDoc)
If modelObjects.Component.IsActive("Part435a:1") Then
	Logger.Info("Part435a:1 is unsuppressed")
Else
	Logger.Info("Part435a:1 is suppressed")
This will work if the first view in the drawing is a view of the assembly.
(If it isn't, you can also get the ModelDocument for particular views.)
The modelObjects object gives you the standard iLogic objects for the assembly document.
In this context, instead of using Component.IsActive you would use modelObjects.Component.IsActive.
Mike Deck
Software Developer
Autodesk, Inc.
