My i Logic rule doesent work in one case
Hello again sorry but i muss know this.
Why doses a iLogic rule in one case his work?
I use If rule for 4 cases. For Supressing and deleting files.
I first 3 i make it work but in 4th it doesent:
If Parameter("Mittelpfosten_vorhanden")=0 Then
Component.IsActive("Mittelpfosten:1") = False
Component.IsActive("Komponentenanordnung 4:1") = False
Component.IsActive("Mittelpfosten:2") = False
Component.IsActive("Komponentenanordnung 5:1") = False
Component.IsActive("Mittelpfosten:3") = False
Component.IsActive("Komponentenanordnung 6:1") = False
Component.IsActive("Untere Lamelle_2:1") = False
Component.IsActive("Obere Lamelle_2:1") = False
Component.IsActive("Obere Lamelle_4:1") = False
Component.IsActive("Obere Lamelle_3:1") = False
Component.IsActive("Obere Lamelle_5:1") = False
Component.IsActive("Untere Lamelle_5:1") = False
If Parameter("Mittelpfosten_vorhanden")=1 Then
Component.IsActive("Mittelpfosten:1") = True
Component.IsActive("Komponentenanordnung 4:1") = True
Component.IsActive("Untere Lamelle_2:1") = True
Component.IsActive("Obere Lamelle_2:1") = True
If Parameter("Mittelpfosten_vorhanden")=2 Then
Component.IsActive("Mittelpfosten:2") = True
Component.IsActive("Komponentenanordnung 5:1") =True
Component.IsActive("Obere Lamelle_4:1") = True
Component.IsActive("Obere Lamelle_3:1") = True
If Parameter("Mittelpfosten_vorhanden")=3 Then
Component.IsActive("Mittelpfosten:3") = True
Component.IsActive("Komponentenanordnung 6:1") = True
Component.IsActive("Obere Lamelle_5:1") = True
Component.IsActive("Untere Lamelle_5:1") = True
InventorVb.DocumentUpdate()
iLogicVb.UpdateWhenDone = True
CCarreiras
The last conditions don't mach with the first 3 ones, can't you see the difference?....
Besides this question was already awnsewerd...why you ask things over and over?
if.............then
elseif..........................then
end if
or use case cycle..... as you want.... Read about the difference between using "if then else" and "case". cycles
USE THESE STATEMENTS FOR THE LAST CONDITION
Component.IsActive("Mittelpfosten:3") = true
Component.IsActive("Komponentenanordnung 6:1") = true
Component.IsActive("Untere Lamelle_5:1") = true
Why not take a little time to study?...
CCarreiras
rossano_praderi
http://forums.autodesk.com/t5/inventor-customization/supress-with-ilogic-with-if-funktion/td-p/56711...
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
