Multiply dxf with filename quantity - from sub assembly
guido_maniglia
Message 1 of 8
guido_maniglia
Hi all,
I'm using this code to extract DXFs from an Inventor assembly.
I have the problem that it don't extract the dxfs from all sub-assembly but only the sheets of the main assembly.
how can I solve?
Code:
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oAsmDoc As AssemblyDocument
Dim ItemQuantiy As String
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = ThisDoc.FileName(False) 'without extension
'Check that the active document is an assembly file
If oDoc.DocumentType <> kAssemblyDocumentObject Then
	MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
	Exit Sub
'get stored value
ItemQuantity = iProperties.Value("Summary", "Keywords")
ItemQuantity = InputBox("Enter the quantity.", "Quantity", ItemQuantity)
If ItemQuantity = "" Then Return
'store the value
iProperties.Value("Summary", "Keywords") = ItemQuantity
'Get user input
RUsure = MessageBox.Show( _
"This will create a DXF file for all of the asembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic  - Batch Output DXFs ", MessageBoxButtons.YesNo)
If RUsure <> vbYes Then Exit Sub
Dim oPath As String = ThisDoc.Path
'Get the DXF target folder path
Dim oFolder As String = oPath & "\" & "DXF Files"
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
	System.IO.Directory.CreateDirectory(oFolder)
'- - - - - - - - - - - - -Component  - - - - - - - - - - - -
'MessageBox.Show("Test", "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
oBOM.StructuredViewEnabled = True
Dim oBOMView As BOMView = oBOM.BOMViews.Item(oBOM.BOMViews.Count)
For Each oRow As BOMRow In oBOMView.BOMRows
	Try
		Dim oCD As ComponentDefinition = oRow.ComponentDefinitions.Item(1)
		Dim iDoc As Document = oCD.Document
		'SheetMetal parts only
		If iDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For
		Dim iName As String = iDoc.FullFileName
		'Check that model is saved
		If iName = vbNullString Then Continue For
		iDoc = ThisApplication.Documents.Open(iName)
		oCD = iDoc.ComponentDefinition
		Dim oItem As String = oRow.ItemNumber
		Try
			If Not oCD.HasFlatPattern Then
				oCD.Unfold()
			Else
				oCD.FlatPattern.Edit()
			Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2018" & _
			"& RebaseGeometry = True" & _
			"& OuterProfileLayer = 0" & _
			"& OuterProfileLayerColor = 0 ;0 ;0" & _
			"& InteriorProfilesLayer = 0" & _
			"& InteriorProfilesLayerColor = 0 ;0 ;0" & _
			"& InvisibleLayers = IV_ARC_CENTERS ;IV_TANGENT ;IV_ROLL ;" & _
				"IV_ROLL_TANGENT ;IV_ALTREP_BACK ;IV_ALTREP_FRONT ;" & _
				"IV_FEATURE_PROFILES_DOWN ;IV_FEATURE_PROFILES ;" & _
				"IV_TOOL_CENTER_DOWN ;DIGI_MARKER_TOOL_1 ;DIGI_MARKER_TOOL_2 ;" & _
				"IV_BEND ;IV_BEND_DOWN "
			Dim oQty As String = oRow.ItemQuantity
			oQty = oQty * ItemQuantity
			Dim ShortName As String = "Qty-" & oQty & "_" & Left(iDoc.DisplayName, _
				(InStrRev(iDoc.DisplayName, ".", -1, vbTextCompare) -1)) & " .dxf"
			oCD.DataIO.WriteDataToFile(sOut, oFolder & "\" & ShortName)
			oCD.FlatPattern.ExitEdit()
		Catch ex As Exception
			MsgBox(ex.Message)
		End Try
		iDoc.Close(True)
	Catch
	End Try
Next
Thx
Replies (7)
Message 2 of 8
Cadkunde.nl
I would suggest going through the assembly like this:
https://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
I see you are going through the bill of material.
Which BoM you go through is depending on the amount of Bom views that are disabled:
So if Model Data, Structured and Parts Only tabs (= 3 tabs) are all enabled. you will go through 'parts only'  (bomviews.count = 3)
You will get different result I think whether you go through Structured or Parts Only.
If you want to force it to go through parts only:
Dim oBOMView As BOMView = oBOM.BOMViews.Item(3)
Message 3 of 8
raith-mb
You can change your Line 50:
to:      PartsOnlyViewEnabled = True
Regards
Roland
Message 4 of 8
guido_maniglia
Dont' work
Message 5 of 8
guido_maniglia
Errore alla riga 51 nella regola: Regola0, nel documento: stack_rev1.iam
Parametro non corretto. (Eccezione da HRESULT: 0x80070057 (E_INVALIDARG))
Message 6 of 8
denis.semeniuc
I also use this code.
It dont work if the level of detail not Master.
Add this code in the start of main code:
 ' Activate level of detail Master
Dim oLOD As LevelOfDetailRepresentation
Dim oAsmCompDef As ComponentDefinition  = oDoc.ComponentDefinition
Try
oLOD = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Item("XX").Activate(True)
Catch
End Try
 Replace "XX" by your name of master level of detail.
CDT.
Message 7 of 8
guido_maniglia
Try
Catch
End Try
CDT.
can you give me an example? I don't understand what they are
Message 8 of 8
denis.semeniuc
your code whith the add in for lever of detail:
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Try
Catch
End Try
	Exit Sub
'get stored value
'store the value
'Get user input
& vbLf & " " _
Dim oBOM As BOM
	Try
		Try
				oCD.Unfold()
			Else
			MsgBox(ex.Message)
		End Try
		iDoc.Close(True)
	Catch
	End Try
Next
Need to replase XX by "Name of Maste Level ofDetails" in your assambly.
My inventor is in Franch, is not the same name.
Cdt.
