Message 1 of 8
Multiply dxf with filename quantity - from sub assembly
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I'm using this code to extract DXFs from an Inventor assembly.
I have the problem that it don't extract the dxfs from all sub-assembly but only the sheets of the main assembly.
how can I solve?
Code:
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oAsmDoc As AssemblyDocument
Dim ItemQuantiy As String
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = ThisDoc.FileName(False) 'without extension
'Check that the active document is an assembly file
If oDoc.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
End If
'get stored value
ItemQuantity = iProperties.Value("Summary", "Keywords")
ItemQuantity = InputBox("Enter the quantity.", "Quantity", ItemQuantity)
If ItemQuantity = "" Then Return
'store the value
iProperties.Value("Summary", "Keywords") = ItemQuantity
'Get user input
RUsure = MessageBox.Show( _
"This will create a DXF file for all of the asembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic - Batch Output DXFs ", MessageBoxButtons.YesNo)
If RUsure <> vbYes Then Exit Sub
Dim oPath As String = ThisDoc.Path
'Get the DXF target folder path
Dim oFolder As String = oPath & "\" & "DXF Files"
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'- - - - - - - - - - - - -Component - - - - - - - - - - - -
'MessageBox.Show("Test", "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
oBOM.StructuredViewEnabled = True
Dim oBOMView As BOMView = oBOM.BOMViews.Item(oBOM.BOMViews.Count)
For Each oRow As BOMRow In oBOMView.BOMRows
Try
Dim oCD As ComponentDefinition = oRow.ComponentDefinitions.Item(1)
Dim iDoc As Document = oCD.Document
'SheetMetal parts only
If iDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For
Dim iName As String = iDoc.FullFileName
'Check that model is saved
If iName = vbNullString Then Continue For
iDoc = ThisApplication.Documents.Open(iName)
oCD = iDoc.ComponentDefinition
Dim oItem As String = oRow.ItemNumber
Try
If Not oCD.HasFlatPattern Then
oCD.Unfold()
Else
oCD.FlatPattern.Edit()
End If
Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2018" & _
"& RebaseGeometry = True" & _
"& OuterProfileLayer = 0" & _
"& OuterProfileLayerColor = 0 ;0 ;0" & _
"& InteriorProfilesLayer = 0" & _
"& InteriorProfilesLayerColor = 0 ;0 ;0" & _
"& InvisibleLayers = IV_ARC_CENTERS ;IV_TANGENT ;IV_ROLL ;" & _
"IV_ROLL_TANGENT ;IV_ALTREP_BACK ;IV_ALTREP_FRONT ;" & _
"IV_FEATURE_PROFILES_DOWN ;IV_FEATURE_PROFILES ;" & _
"IV_TOOL_CENTER_DOWN ;DIGI_MARKER_TOOL_1 ;DIGI_MARKER_TOOL_2 ;" & _
"IV_BEND ;IV_BEND_DOWN "
Dim oQty As String = oRow.ItemQuantity
oQty = oQty * ItemQuantity
Dim ShortName As String = "Qty-" & oQty & "_" & Left(iDoc.DisplayName, _
(InStrRev(iDoc.DisplayName, ".", -1, vbTextCompare) -1)) & " .dxf"
oCD.DataIO.WriteDataToFile(sOut, oFolder & "\" & ShortName)
oCD.FlatPattern.ExitEdit()
Catch ex As Exception
MsgBox(ex.Message)
End Try
iDoc.Close(True)
Catch
End Try
Next
Thx
