multi value list giving me trouble
so I'm trying to set up a text parameter that tells the boys in the shop which machine to use to cut out the part I've designed when I hand the design off to them. I WAS using a boolean parameter for a while and it worked but now I need to have more than 2 options on the list to choose from and that's where things get weird. I'm trying to have a multi value list that opens up when I launch the file so I can tell it which machine we're using (plasma, shear or saw) and so far the iLogic code isn't cooperating...  i keep getting this error:
'Error in rule: ProcessRule, in document: Part10
Object reference not set to an instance of an object.'
here is my code so far. please help?
SyntaxEditor Code Snippet
MultiValue.SetList("Machine", Plasma, Shear, Saw)
Machine_Process = InputListBox("Select Process", MultiValue.List("Machine"), Machine, Title := "Process", ListName := "List")
martin.jacko
I think your code should be
MultiValue.SetList("Machine", "Plasma", "Shear", "Sawer")
Martin
j.romo
First you have to create a External Rule to run a rule to add the multivalue parameter with this code
'THIS WILL CREATE A MULTIVALUE USER PARAMETER
oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
''THIS WORKS NOTE PARAMETERS WILL BE ADDED IN THE EXACT ORDER THEY ARE GENERATED IN THIS LIST
oParameter = oMyParameter.AddByValue("Machine", "Plasma", UnitsTypeEnum.kTextUnits)
MultiValue.SetList("Machine", "Plasma", "Shear", "Saw")
and a second rule with this code to run the input list
Machine = InputListBox("Prompt", MultiValue.List("Machine"), Machine, Title := "Title", ListName := "List")
 Or you can combine them but if you run the rule to create the Multivalue parameter but each time you run the rule to change the machine parameter it will create a new parameter **_1
So use 2 rules instead
