iLogic code to synchronize view rep. with pos. rep of same name.
I found some code on this forum that works very well on a small test assembly.
When I use it on my larger target assembly it does not work under an iLogic trigger.
It does, however, work when the rule is run explicitly from the ilogic browser.
I have tried saving the rule under a new name directly in the assembly. It did not work, but I can run it explicitly and it works.
Any ideas?
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
If oAsmCompDef.RepresentationsManager.ActivePositionalRepresentation.Name = "Master"Then
'If the pos rep is the Master then activate the Default view rep
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Default").Activate
Else
Try
'Try to active a view rep with the same name as the active pos rep
'So if "two" is the current pos rep it will try to active the View rep "two"
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(oAsmCompDef.RepresentationsManager.ActivePositionalRepresentation.Name).Activate
Catch
'If a view rep with the same name as the active pos rep doesn't exist set the default view rep active
End Try
Mark.Lancaster
@Anonymous
Programming questions and issues for Inventor need to be raised in the Inventor Customization forum.  I will have the moderator relocate it there to better suit your needs.
https://forums.autodesk.com/t5/inventor-customization/bd-p/120
Mark Lancaster
Thnx
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Can you please specify event trigger which is not working? Also please provide large assembly to test?
Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
I have tried
This document: Trigger on any model parameter change
Assemblies: Any model parameter change
The assembly is very large 9397kb
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Without Assembly file, unable to identify the root cause of issue. If assembly file is there, we can identify issue and suggestion can be given.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Packngo is 200meg
Going to need an FTP site
