Multi-Line General Note (Carriage Return Line Feed)?? Help.
Tiffany_Hayden_
Tiffany_Hayden_
I'm trying to make a multiline general note. And I tried adding the /n/r and \n\r to my string to split the string into multiple lines and VBA doesn't seem to care about those. Below is my code.
    Dim oDrawdoc As DrawingDocument
    Set oDrawdoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDrawdoc.Sheets.Item(1)
    Dim oSheets As Sheets: Set oSheets = oDrawdoc.Sheets
    Dim oGeneralNotes As GeneralNotes
    Set oGeneralNotes = ThisApplication.ActiveDocument.ActiveSheet.DrawingNotes.GeneralNotes
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    Dim strText_Elevation As String
    strText_Elevation = "1. ALL ELEVATIONS TAKEN FROM FINISHED FLOOR."
    Dim strtext_Supports As String
    strtext_Supports = "2. ALL SUPPORTS TO HAVE ?1" & """" & "CLEARANCE FROM FINISHED FLOOR."
     Dim strFullNote As String
    strFullNote = strText_Elevation & "/r/n" & strtext_Supports
    Dim oGeneralNote As GeneralNote
    Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(0.5, 2), strFullNote)
    oGeneralNotes.Item(oGeneralNotes.Count()).TextStyle.FontSize = 0.6 * 0.254
    oGeneralNotes.Item(oGeneralNotes.Count()).TextStyle.Rotation = pi / 2
Any help would be greatly appreciated.
Thank you!
Tiffany Hayden
Tiffany_Hayden_
bump for help.
Tiffany Hayden
Tiffany_Hayden_
Just figured it out.
Example:
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oPosition As Point2d
    Set oPosition = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
    Dim sFormattedText As String
    sFormattedText = "<Numbering Format='" & "1" & "'>" & strText_Elevation & "</Numbering>" & "<Numbering Format='" & "1" & "'>" & strtext_Supports & "</Numbering>"
Tiffany Hayden
JBerns
@Tiffany_Hayden_,
Very helpful. Thanks.
I was trying to unsuccessfully include an ampersand (&) character in the string. I had to use the VBA editor to explore a formatted string.
Here is the format to use "&" in your strings:
Dim strText_Line1 As String = "BEFORE &amp; AFTER"
Wish it was easier to explore objects in iLogic. Thanks again for the formatting example.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Tiffany_Hayden_
@JBerns
Great info! Thank you
Tiffany Hayden
JBerns
Welcome.
- Jerry
CAD Administrator
