multi-body parts visibility
SpokenEarth
SpokenEarth
Help needed with multi-body visibility.
check the link.
https://www.youtube.com/watch?v=XizjzCszDNg&ab_channel=KLONG
SpokenEarth
THE CODE I USED FOR CONTROL VISIBILITY:
Public Sub Main()
Select Case DIN
'DIN
Case "DIN 32676 SERIES 1"
setVisibility("DIN32676SERIES1",True)
setVisibility("DIN32676SERIES2STANDARD",False)
setVisibility("DIN32676SERIES2NONSTANDARD", False)
setVisibility("DIN32676SERIES3", False)
setVisibility("DIN11850", False)
setVisibility("ISO2037SERIES1", False)
setVisibility("ISO2037SERIES2", False)
setVisibility("ISO1127SERIES1", False)
Case "DIN 32676 SERIES 2 STANDARD"
setVisibility("DIN32676SERIES1",False)
setVisibility("DIN32676SERIES2STANDARD",True)
Case "DIN 32676 SERIES 2 NON STANDARD"
setVisibility("DIN32676SERIES2NONSTANDARD", True)
Case "DIN 32676 SERIES 3"
setVisibility("DIN32676SERIES2NONSTANDARD",False)
setVisibility("DIN32676SERIES3", True)
Case "DIN 11850"
setVisibility("DIN32676SERIES3",False)
setVisibility("DIN11850", True)
'ISO
Case "ISO 2037 SERIES 1"
setVisibility("ISO2037SERIES1", True)
Case "ISO 2037 SERIES 2"
setVisibility("ISO2037SERIES2", True)
Case "ISO 1127 SERIES 1"
setVisibility("ISO1127SERIES1", True)
End Select
End Sub
Public Sub setVisibility(bodyName As String, visible As Boolean)
Dim doc As PartDocument = ThisDoc.Document
Dim def As PartComponentDefinition = doc.ComponentDefinition
Dim bodies As IEnumerable(Of SurfaceBody) = def.SurfaceBodies.Cast(Of SurfaceBody)
Dim body As SurfaceBody = bodies.
Where(Function(b) b.Name.Equals(bodyName)).First()
body.Visible = visible
End Sub
A.Acheson
It either needs an update or  needs a physical geometry change to update the graphics. When switching category and just below where the visibility of the forms is triggered type in the model variables you want to see as your default when you switch, say smallest in the category.
Regards
Alan
SpokenEarth
Spot on.... do you have any solution?
JMGunnar
Check this blogspot
 MultiValue.SetValueOptions(True, DefaultIndex := 0)
http://inventbetter.blogspot.com/2016/05/multi-value-list-controls.html
