Move all constraints from one component instance to another instance of that same component.
briant.markham
briant.markham
I would like to use ilogic to transfer all the mates on one component to another instance of that same component. I would settle for ilogic which does the equivalent of editing a mate unselecting #1 and then reselecting the same feature on the new instance of the same part. If I had that I could probably get it to loop through all the mates on the component and make it user-friendly with some prompts and the like.
richterBKSAC
Hey Briant,
I created an ilogic which could be used as framework, since you would have to add some "select" statements, amongst others, to include all the other types of mates.
Copy the code into a rule and add the rule to a form then select the source part and hit the button of the rule.
To clarify what it does, here is the internal tree I've used:
  • ActiveDocument
    •  SelectSet
      • Item(x)
        • Constraints
          • Item(x)
            • .Type
            • EntityOne
              • .InternalName
            • EntityOneInferredType
            • EntityTwo
            • Offset
              • .Value
            • AffectedOccurrenceOne
              • .Name
      • Definition
        • Document
          • .FullFileName
    • ComponentDefinition
      • Occurrences
        • Item(x)
          • SurfaceBodies
            • Item(1)
              • Faces
                • Item(x)
                  • .InternalName
        • Definition
          • Document
            • .FullFileName
EntityOne represents in the case of a mate constraint the face of the part you've selected. So I grabbed the InternalName of that face to search for it in the other occurences of that part. EntityTwo represents the counterpart face.
I've tested it with only one mate constraint on the source part, just to see if it would work at all.
Please test it in a safe environment.
Dim actDoc As Document
Dim IAM_Occ As ComponentOccurrences
Dim IAM_OccItem As ComponentOccurrence
Dim selected_Occs As SelectSet
Dim sourceEntityOne As Object
Dim sourceEntityOne_InternalName As String
Dim sourceEntityOne_Name As String
Dim sourceEntityOne_InferredType As InferredTypeEnum
Dim sourceEntityOne_FullFileName As String
Dim source_Offset As Double
Dim sourceEntityTwo As Object
Dim sourceEntityTwo_InferredType As InferredTypeEnum
Dim sourceConstraints As AssemblyConstraintsEnumerator
Dim IAMConstraints As AssemblyConstraints
Dim target_InternalName As String
Dim targetFaces As Faces
Dim targetFace As Face
Dim target_FullFileName As String
Dim targetFace_match As Face
actDoc = ThisApplication.ActiveDocument
actDocType = ThisApplication.ActiveDocumentType
IAMConstraints = actDoc.ComponentDefinition.Constraints
'check if the IAM has any occurences yet
If Not actDoc.ComponentDefinition.Occurrences.Count = 0 Then
    IAM_Occ = actDoc.ComponentDefinition.Occurrences
	selected_Occs = actDoc.SelectSet
Else
	MsgBox("Assembly has no Occurences yet",,"Error")
	Return
End If
If selected_Occs.Count = 1 Then
	sourceConstraints = selected_Occs.Item(1).Constraints
Else
	MsgBox("Select the source occurrence",,"Error")
	Return
End If
source_Offset = sourceConstraints.Item(1).Offset.Value
sourceEntityOne = sourceConstraints.Item(1).EntityOne
sourceEntityOne_Name = sourceConstraints.Item(1).AffectedOccurrenceOne.Name
sourceEntityOne_InternalName = sourceConstraints.Item(1).EntityOne.InternalName
sourceEntityOne_InferredType = sourceConstraints.Item(1).EntityOneInferredType
sourceEntityOne_FullFileName = selected_Occs.Item(1).Definition.Document.FullFileName
sourceEntityTwo_InferredType = sourceConstraints.Item(1).EntityTwoInferredType
sourceEntityTwo = sourceConstraints.Item(1).EntityTwo
For Each IAM_OccItem In IAM_Occ
	If Not IAM_OccItem.Name = sourceEntityOne_Name Then
		If IAM_OccItem.Definition.Document.FullFileName = sourceEntityOne_FullFileName Then
			targetFaces = IAM_OccItem.SurfaceBodies.Item(1).Faces
			For Each targetFace In targetFaces
				If targetFace.InternalName = sourceEntityOne_InternalName Then
					targetFace_match = targetFace
					IAMConstraints.AddMateConstraint(sourceEntityTwo, targetFace_match, source_Offset,sourceEntityOne_InferredType, sourceEntityTwo_InferredType)
				End If
			Next
		End If
	End If
Next
best regards
Matthias
