Modifying sub-assembly in main assembly using forms
doug.johnston
doug.johnston
Hey all,
I am a beginner at illogic, so I don't know how to do this specific task ( I hope I can explain it properly).
I have a main assembly that contains several sub-assemblies.  I want to be able to have a form in the main assembly that will open the sub-assembly form when I need to edit the sub-assembly.
The attached picture is similar to want I would like.  The user has an the "EDIT" button in the main form that opens the sub-assembly form and then modifies the sub-assembly by changing values / suppression / etc.
How is this done ???
Any assistance would be appreciated.
Doug J.
It's not easy maintaining this level of insanity !!!!!
rikard.nilsson
Test this.
In main assembly use iLogicVb.RunRule(“componentName”, “ShowFormRule”)
In subassembly use the snippet ShowForm(“formName”) in a rule called ShowFormRule
/Rikard
doug.johnston
Works perfect ... thank you !!!
