Modify default values in dialog boxes
TONELLAL
Message 1 of 15
TONELLAL
When you create a new Frame Generator assembly, you have a dialog box with Frame name, Path to frame file, Skeleton name, path to skeleton file. Inventor propose default values. Is there a way to automatically modify these default values ? For example, instead Inventor propose "New Frame file name = Frame0001.iam", I want a custom calculated file name. Is it possible ?
Replies (14)
Message 2 of 15
xiaodong_liang
Autodesk Support
Autodesk Support
The event FileUIEvents.OnPopulateFileMetadata provides you to suggest the name when file names and properties are being generated by a command. Hope it helps.
Class1 code:
Option Explicit
Private WithEvents fileUIEvts As FileUIEvents
Private Sub Class_Initialize()
   Set fileUIEvts = ThisApplication.FileUIEvents
End Sub
Private Sub Class_Terminate()
   Set fileUIEvts = Nothing
End Sub
Private Sub fileUIEvts_OnPopulateFileMetadata(ByVal FileMetadataObjects As ObjectsEnumerator, ByVal Formulae As String, ByVal Context As NameValueMap, HandlingCode As HandlingCodeEnum)
   Dim oMetaData As FileMetadata
   If FileMetadataObjects.Count 0 Then
   For Each oMetaData In FileMetadataObjects
          oMetaData.FileName = "asdk_" & oMetaData.FileName
         oMetaData.FileNameOverridden = True
   Next oMetaData
   HandlingCode = kEventHandled
End Sub
Module code:
Private cls As Class1
Sub startcmd()
Set cls = New Class1
End Sub
Sub Endcmd()
Set cls = Nothing
End Sub
Message 3 of 15
TONELLAL
This seems to be what I'm looking for !
But I'm not really a programmer, so it is difficult for me to use it . Do you have a more detailed example, where you effectively modify dialog box values ?
Message 4 of 15
TONELLAL
I finally found how to use it, but :
-how can I use Context ? I think it is used to know why the event fired, but Its value is always 0.
-what is the format and how function Formulae ?
-if I have a dialog box with several FileMetaData objects (for example when using Frame generator : in the same dialog box, you have the skeleton properties (name/path) and the frame properties (name/path)) . How can I make the difference ?
Message 5 of 15
xiaodong_liang
Autodesk Support
Autodesk Support
1. Context:  you have the correct understanding. The attachments are my test. The context tells why the event fires. It is NOT empty
2. Formulae: from help reference, this is  an input String that specifies XML-based formulae for generating file name, display name and file properties. This can be a null string. Sorry I have not a sample at hand
3. This question is not clear to me. When FG is insterted, the event fires twice (see attached snapshots), in each, you have the chance to modify the name for FG assembly. FG skeleton and the FG element.
Message 6 of 15
TONELLAL
Thanks for your informations !
1-Ok, I was not watching on the right place. I suppose Context.Item(1) is the "type", and Context.Item(2) is the "sub-type" ?
2-Formulae : I read the help, do you know if I can found more information about this ?
3-Effectively, using Context.item I can diffrentiate FG assembly, FG skeleton and the FG element, and modify name/path. So it is ok for FG. But what about Piping ? In this case, I have a similar dialog box with name/path for the piping and for the routing, but Context is empty. The event is yet fired twice (see screen shots).
Message 7 of 15
Hello Tonellal,
Is it possible to share the working code? because I can't get the sample given above working properly.
Is it actually possible to use the same principle to populate differnt fields in different commands?
Thx
Chris
Message 8 of 15
TONELLAL
Here is the code :
'in module
Private Sub startcmd()
Dim dd
Set cls = New Class2
End Sub
'in "Class2" class module
   Dim str As String
   str = ThisApplication.CommandManager.ActiveCommand 'Put here a breakpoint to watch Context
   If FileMetadataObjects.Count > 0 Then
          oMetaData.FileName = "FG filename" & oMetaData.FileName
          oMetaData.FullFileName = "FG fullfilename"
   Next oMetaData
End Sub
1/ You use the command "Insert a profile" :
-in the FG dialog box, select the profile and place it
-when you "Apply" or "OK", you stop on the breakpoint, so you ca watch Context, wich contains Item 1 = "Frame Generator" and item 2 = "Frame".
-the event fire several times, you can know why by testing Item 2 : frame, skeleton or member, then for each set values for oMetadata.
2/ You use the command "Create a piping route" :
-the event fire, so you stop on the breakpoint. Problem : Context = 0 !! So, how can you know if you are on the Piping assembly, or on the piping route ?
Message 9 of 15
xiaodong_liang
Autodesk Support
Autodesk Support
hum...sorry, it is also true to me the context is empty for Pipe/Cable. But we have way to know if the current assembly is pipe.
By using the respective GUID for the ADD-In, it’s possible to determine the type of document. Following are GUID for the Cable and Harness, Tube and Piping ,Frame Generator and Design Accelator Add-in’s. Using these GUID in the DocumentInterests.HasInterest property, we can determine the type of the document.
'Cable & Harness routing - {C6107C9D-C53F-4323-8768-F65F857F9F5A}
'Tube & Pipe routing - {4D39D5F1-0985-4783-AA5A-FC16C288418C}
'Autodesk Frame Generator Add-in - {AC211AE0-A7A5-4589-916D-81C529DA6D17}
'Design Accelerator Add-in - {BB8FE430-83BF-418D-8DF9-9B323D3DB9B9}
Sub DocHasInteres()
Dim odocints As DocumentInterests
Set odocints = ThisApplication.ActiveDocument.DocumentInterests
Dim hasinterest As Boolean
'Check for Tube and Pipe routing
hasinterest = odocints.hasinterest("{4D39D5F1-0985-4783-AA5A-FC16C288418C}")
If hasinterest Then
Dim odocint As DocumentInterest
For Each odocint In odocints
'Will be FrameDoc for the frame document
Debug.Print odocint.Name
Next
End Sub
Message 10 of 15
TONELLAL
Ok, this indicate if the active document use a particular add-in. But I don't understand how I can use this to know, when there is a OnPopulateFileMetadata event, that this event come from this add-in ?
Message 11 of 15
xiaodong_liang
Autodesk Support
Autodesk Support
from help doc: DocumentInterest provides a means for an application to register an interest in a document. In another words, to flag the document as containing application-specific data, and to set the data version (for example, so Inventor can determine whether data migration is required and so fire the appropriate event).
While OnPopulateFileMetadata is just an event when file names and properties are being generated. So, you should be able to use it anytime.
Message 12 of 15
Will you please help me out with frame generator default values.
I have create an ilogic rule that opens an assembly file asks you for a part number to save it. Then adds a part into the assembly as a phantom part and with the same part number as the assembly.
Then when we enter frame parts I want the create new frame dialog box to default to Frame & part number and also the skeleton & part number.
Then if possible when placing the member if the filename of the members can default to part number & 001,002 etc.
Message 13 of 15
TONELLAL
Hi Tony,
I use fileUIEvts_OnPopulateFileMetadata to detect if you are creating aFrame iam or inserting a Frame member. I see you are able to modify  frame and skeleton name, it is the same thing for frrame member name : with context(1) you detect if  you are in FG, if yes with context(2) you detect if you are creating frame/skeleton or inserting a member.
I think what your are searching is in bold :
'Modifie les noms des fichiers Frame, Squelette et des membres FG, en fonction de ce qui est défini dans le formulaire Form_Renommage_FG_Actif_Inactif
Dim NomProjet As String
Dim NomStruct As String
Dim NomSousEnsemble As String
Dim Increment As String
Dim newFilename As String
Dim SplitFilename() As String
Dim NumFer As String
Dim i 'As Integer
If Context.Count <> 0 Then
    If Context.item(1) = "Frame Generator" Then 'If context is FG
        Select Case Context.item(2)
            Case "Frame, Skeleton" 'Frame and Skeleton treatment
                'FG iam name
                Set oMetaData = FileMetadataObjects.item(1)
                oMetaData.DisplayName = .....
                oMetaData.FileName = .....
                'Skeleton name
                Set oMetaData = FileMetadataObjects.item(2)
            Case "Frame Member" 'Frame member treatment
                    newFilename = ""
                    SplitFilename = Split(oMetaData.FileName, " ")
                    'Get only the last 3 digits from the default name
                    NumFer = Right(SplitFilename(UBound(SplitFilename)), 3)
                   'Get here the part number from your phantom part
                    PartNumber = .....
                   'Create the new filename
                    newFilename =PartNumber & NumFer
                    oMetaData.DisplayName = newFilename
                    oMetaData.FileName = newFilename
                Next oMetaData
        End Select
End Sub
Message 14 of 15
Hi
I am not that good in VBA can you help me a bit further.
If you edit the code so that it works I could probably then work out what I need to change.
Many Thanks.
Message 15 of 15
I have it working exactly as I wanted it.
many thanks.
