Determining ipt file type
isocam
isocam
Can anybody help?
Is it possible, using Inventors VBA to determine if a "ipt" file is a "Normal File" or a "Sheet Metal File".
Say I have created a sheet metal component and a normal component.
If i run a VBA macro, can I tell which one is the "Sheet Metal" component?
Many thanks in advance!!!
TONELLAL
In the properties, you can use the Sub file type.
Public Sub PartTest()
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    If oPartDoc.ComponentDefinition.Type = kPartComponentDefinitionObject Then
        MsgBox ("Standard part")
    ElseIf oPartDoc.ComponentDefinition.Type = kSheetMetalComponentDefinitionObject Then
        MsgBox ("SheetMetal")
End Sub
