Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Modification of overall dimension code
floccipier
Message 1 of 12
floccipier
http://hjalte.nl/37-auto-overall-dimension
Hi @JelteDeJong just checked your code for overall dimensions and this is working brilliantly.
Instead of running this on individual views I want to run it on all views of the open drawing. if you could please modify this, that would be awesome.
Thank you.
Replies (11)
Message 2 of 12
floccipier
here is code if someone else gets a chance to find solution:-
Public Class ThisRule
	' This code was written by Jelte de Jong
	' and published on www.hjalte.nl
    Private _doc As DrawingDocument
    Private _sheet As Sheet
    Private _view As DrawingView
    Private _intents As List(Of GeometryIntent) = New List(Of GeometryIntent)()
    Sub Main()
        _doc = ThisDoc.Document
        _sheet = _doc.ActiveSheet
        _view = ThisApplication.CommandManager.Pick(
                       SelectionFilterEnum.kDrawingViewFilter,
                       "Select a drawing view")
        CreateIntentList()
        createHorizontalOuterDimension()
        createVerticalOuterDimension()
    End Sub
    Private Sub createHorizontalOuterDimension()
        Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.X)
        Dim pointLeft = orderedIntents.First
        Dim pointRight = orderedIntents.Last
        Dim textX = pointLeft.PointOnSheet.X +
                (pointRight.PointOnSheet.X - pointLeft.PointOnSheet.X) / 2
        Dim textY = _view.Position.Y + _view.Height / 2 + 2
        Dim pointText = ThisApplication.TransientGeometry.CreatePoint2d(textX, textY)
        _sheet.DrawingDimensions.GeneralDimensions.AddLinear(
            pointText, pointLeft, pointRight, DimensionTypeEnum.kHorizontalDimensionType)
    End Sub
    Private Sub createVerticalOuterDimension()
        Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.Y)
        Dim pointLeft = orderedIntents.Last
        Dim pointRight = orderedIntents.First
        Dim textY = pointLeft.PointOnSheet.Y +
                (pointRight.PointOnSheet.Y - pointLeft.PointOnSheet.Y) / 2
        Dim textX = _view.Position.X - _view.Width / 2 - 2
            pointText, pointLeft, pointRight, DimensionTypeEnum.kVerticalDimensionType)
    End Sub
    Private Sub addIntent(Geometry As DrawingCurve, IntentPlace As Object, onLineCheck As Boolean)
        Dim intent As GeometryIntent = _sheet.CreateGeometryIntent(Geometry, IntentPlace)
        If intent.PointOnSheet Is Nothing Then Return
        If onLineCheck Then
            If (IntentIsOnCurve(intent)) Then
                _intents.Add(intent)
            End If
        Else
        End If
    End Sub
    Private Function IntentIsOnCurve(intent As GeometryIntent) As Boolean
        Dim Geometry As DrawingCurve = intent.Geometry
        Dim sp = intent.PointOnSheet
        Dim pts(1) As Double
        Dim gp() As Double = {}
        Dim md() As Double = {}
        Dim pm() As Double = {}
        Dim st() As SolutionNatureEnum = {}
        pts(0) = sp.X
        pts(1) = sp.Y
        Try
            Geometry.Evaluator2D.GetParamAtPoint(pts, gp, md, pm, st)
        Catch ex As Exception
            Return False
        End Try
        Return True
    End Function
    Private Sub CreateIntentList()
        For Each oDrawingCurve As DrawingCurve In _view.DrawingCurves
            Select Case oDrawingCurve.ProjectedCurveType
                Case _
                        Curve2dTypeEnum.kCircleCurve2d,
                        Curve2dTypeEnum.kCircularArcCurve2d,
                        Curve2dTypeEnum.kEllipseFullCurve2d,
                        Curve2dTypeEnum.kEllipticalArcCurve2d
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularTopPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularBottomPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularLeftPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularRightPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kEndPointIntent, False)
                    addIntent(oDrawingCurve, PointIntentEnum.kStartPointIntent, False)
                Case _
                        Curve2dTypeEnum.kLineCurve2d,
                        Curve2dTypeEnum.kLineSegmentCurve2d
                Case _
                    Curve2dTypeEnum.kPolylineCurve2d,
                    Curve2dTypeEnum.kBSplineCurve2d,
                    Curve2dTypeEnum.kUnknownCurve2d
                    ' Unhandled curves types
                Case Else
            End Select
        Next
    End Sub
End Class
Message 3 of 12
JelteDeJong
try this rule it will loop over all sheets and all drawingviews.
    Sub Main()
		For Each sheet In _doc.sheets
			_sheet = Sheet
			For Each view In _sheet.DrawingViews
				_view = View
				_intents =  New List(Of GeometryIntent)()
				CreateIntentList()
			Next
		Next
    End Sub
    End Sub
    End Sub
        If onLineCheck Then
            End If
        Else
        End If
    End Sub
        pts(0) = sp.X
        pts(1) = sp.Y
        Try
            Return False
        End Try
        Return True
    End Function
                Case _
                Case _
                Case _
                Case Else
            End Select
        Next
    End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
Message 4 of 12
floccipier
Thank you so much - its not much but morning coffee is on me.
Message 5 of 12
JelteDeJong
Thank you for the coffee I appreciate it a lot 😄
Jelte de Jong
Message 6 of 12
robertast
@JelteDeJong
good job, beer sent for your job
Message 7 of 12
robertast
@JelteDeJong
Tell me, are there any holes in the details at your job? Maybe such a problem, auto size of the position of the holes, when you come up with a solution. 😉
Then I'll run for wine 😉
Message 8 of 12
JelteDeJong
@robertastThank you for the Beer 😄
Jelte de Jong
Message 9 of 12
JelteDeJong
@robertast
It's not completely clear what you need. Maybe you could post a screenshot of what you envision. Maybe it's a good topic for a new blog post 😉
Jelte de Jong
Message 10 of 12
robertast
@JelteDeJong
I drew the furniture and spent most of my time marking the dimensions of the holes. I don’t know if it can be automated, but the basics of your work thought you might succeed. If the program would add large amounts of dimensions, it would not be bad to delete them faster than to add them again.
Message 11 of 12
benigno.martinezvaldez
Hi
I have a rule that make 2d Drawing for all my stps in specific Path , send to print , and close the stp file.
How can i call this Class ? i made it by diferents ways but don work
If a run the Class directly , i dont have problem
This is my main Rule  , and i have other rules to make this into all the files in a specific Path
Imports Inventor.ViewOrientationTypeEnum
Imports Inventor.DrawingViewStyleEnum
Imports System.Windows.Forms
Dim oDrawingDoc as DrawingDocument
Dim oPartDoc as Document
Dim oSheet As sheet
Dim oView1 as DrawingView
Dim oView2 as DrawingView
Dim oView3 as DrawingView
Dim oView4 as DrawingView
' Obtener la medida en cada eje , con precision de 2 decimales.
Medidaenx=Round(Measure.ExtentsLength,2)
Medidaeny=Round(Measure.ExtentsWidth,2)
Medidaenz=Round(Measure.ExtentsHeight,2)
' Se obtiene el nombre del STP sin la extension.
Dim name As String
name=ThisDoc.FileName(False)
' Se evalua las 3 medidas de bloque x , y , z y se obtiene la mayor , dicha medida se divide por el factor y esa es la escala de las vistas
Escala=MaxOfMany(medidaenx, medidaeny, medidaenz)
ViewScale = 91/escala
    oPartDoc = ThisDoc.Document
    'Check to see if part is a sheetmetal part
    If oPartDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
        'do nothing
    Else
        'ensure this part has a flat pattern
        Dim oSMDef As SheetMetalComponentDefinition
        oSMDef = oPartDoc.ComponentDefinition
        If oSMDef.FlatPattern Is Nothing Then
        'create flat pattern
        oSMDef.Unfold
        oSMDef.FlatPattern.ExitEdit
        oSMDef.FlatPattern.FlipBaseFace
        Else
        'do nothing
        End If
    End If
    'Se define la ubicacion del Template
    oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "O:\Operaciones\Maquinado\OTs\FFA-01-19 Dibujo estandar.idw", True)
    oSheet = oDrawingDoc.Sheets.Item(1)
 ' Create a new NameValueMap object
  Dim oBaseViewOptions As NameValueMap
  oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
 'True = folded view  False = flat pattern view
  oBaseViewOptions.Add("SheetMetalFoldedModel", False)
'Se define el punto inferior izquierdo para cada una de las vistas
oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(9, 10) ' front view
oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(9, 20) ' top view
oPoint3 = ThisApplication.TransientGeometry.CreatePoint2d(28, 10)' right view
oPoint4 = ThisApplication.TransientGeometry.CreatePoint2d(28, 20)' iso
 ' Se abre un sketch para generar los textos
    Dim oSketch As DrawingSketch
        oSketch = oDrawingDoc.ActiveSheet.Sketches.Add
    ' Open the sketch for edit so the text boxes can be created.
    ' This is only required for drawing sketches, not part.
    oSketch.Edit
    Dim oTG As TransientGeometry
        oTG = ThisApplication.TransientGeometry
' Se define el texto y posiciona el texto Medidas de corte
Dim sText1 As String
    sText1 ="Medidas de corte "
    Dim oTextBox1 As inventor.TextBox
        oTextBox1 = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(36, 24), sText1)
' Se define y posiciona el texto con los valores de bloque
Dim sText As String
    sText =" X "& medidaenx & "  Y" & medidaeny & "  Z" & medidaenz
    Dim oTextBox As inventor.TextBox
        oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(36, 23), sText)
' Se define y pocisiona el texto con el nombre del archivo
    Dim oTextbox2 As inventor.Textbox
        oTextbox2 = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(9, 26), name)
' Se da formato a los textos
oTextbox.Formattedtext = "<StyleOverride FontSize='" & .4 & "'>" _
& oTextbox.Text & "</StyleOverride>"
oTextbox1.Formattedtext = "<StyleOverride FontSize='" & .4 & "'>" _
& oTextbox1.Text & "</StyleOverride>"
oTextbox2.Formattedtext = "<StyleOverride FontSize='" & .4 & "'>" _
& oTextbox2.Text & "</StyleOverride>"
' Se posicionan las vistas
oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint1, ViewScale,kFrontViewOrientation, kHiddenLineDrawingViewStyle, "My View")
oView2 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint2, kHiddenLineDrawingViewStyle, ViewScale)
oView3 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint3, kHiddenLineDrawingViewStyle, ViewScale)
oView4 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint4, kHiddenLineDrawingViewStyle, (ViewScale/1.15))
' Se cierra el Sketch
oSketch.ExitEdit
Message 12 of 12
Luis_Pacheco_3D
hi @JelteDeJong , i found this code in your webpage, this works.
but i would like when the rule generate the dimension, add a text.
see image:
i´ve been trying for a several days, but i could not do it. Can you help me? Than you.
