Model State Documents File save counter difference when using inventor 2022
jmacapagal2CD9H
jmacapagal2CD9H
Hello everyone,
Using inventor 2022, I noticed the model state factory document and member document was not sharing the same file save counter. In my case, I added a new model state on my part(file save counter is 3 and current document loaded in the memory was part model state factory document), I didn't save the part and attached it an assembly(in this case inventor will load the part model state member document). When I check their file save counter the part model state factory document was 3 and the part model state member document was reset to 0. When I checked the same test case using inventor 2023 both member and factory shares the same file save counter which is 3. Does anyone know if this solved/fixed in the latest service pack or releases of Inventor 2022?
I will also attached my findings.
"Model state 1"  is my newly added model state on the part.
Inventor 2023
Inventor 2022
WCrihfield
Hi @jmacapagal2CD9H.  I am using 2022.4 and when I loop through the ModelStates of one of my parts, I am also getting different values for the FileSaveCounter of each ModelState.Document.  Interesting.  Must have been a bug that got fixed in 2023.
Wesley Crihfield
(Not an Autodesk Employee)
jmacapagal2CD9H
I badly needed that info as I having problem with updating to latest sp. Thank you so much.
