I have a exsternal rule that changes the iproperties description of a part by using OrientedMinimumRangeBox. I use the description in the parts list to show the outer dimension of plates e.g. "PL - 5x120x250".
Since I only use this on some parts, I want to add it to the event trigger Part Geometry Change with the same rule, so i dont have to manually rerun the rule when i make modifications of the part.
Is this possible?
Thank you in advance for your help!
