Hi @WCrihfield , this is pretty much the whole rule.
The part that errors is straigt copy paste of someone else code that i also just tested.
That one also gives an error for the same line of code when in a model state.
Hope this helps.
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
Dim oAssyDef As AssemblyComponentDefinition
oAssyDef = oAssyDoc.ComponentDefinition
Dim openDoc As Inventor.Document
Dim docFile As Inventor.Document
openDoc = ThisApplication.ActiveDocument
'set a reference to the BOM
Dim oBOM As BOM
oBOM = oAssyDef.BOM
'set a reference to the "Parts Only" BOMView
Dim oBOMView As BOMView
oBOM.PartsOnlyViewEnabled = True
oBOMView = oBOM.BOMViews.Item("Parts Only")
Dim oBOMRow As BOMRow
For Each docFile In openDoc.AllReferencedDocuments
'MsgBox(docFile.FullFileName)
If docFile.DocumentType = kPartDocumentObject Or docFile.DocumentType = kAssemblyDocumentObject Then
If docFile.FullFileName.Contains("Content") Or docFile.FullFileName.Contains("Standard parts") Then Continue For
Totalname = docFile.FullFileName
Dim Bestandsnaam As String
Dim BestandsnaamMetExtentie As String
Bestandsnaam = IO.Path.GetFileNameWithoutExtension(Totalname)
BestandsnaamMetExtentie = IO.Path.GetFileName(Totalname)
StockNumber = iProperties.Value(BestandsnaamMetExtentie, "Project", "Stock Number")
PartNumber = iProperties.Value(BestandsnaamMetExtentie, "Project", "Part Number")
RevisionNumber = iProperties.Value(BestandsnaamMetExtentie, "Project", "Revision Number")
Dim StockNumberLength As Integer
StockNumberLength = StockNumber.length
If StockNumberLength <> 14 Then
MsgBox("Controleer op stocknumber en gelinkte bestanden" & vbCrLf & vbCrLf & Totalname)
Exit sub
End If
Stockdeel1 = (Left(StockNumber, (InStr(StockNumber, "-")) -1))
Stockdeel2 = (Right(StockNumber, (3)))
For Each oBOMRow In oBOMView.BOMRows
Dim oCompDef As ComponentDefinition
oCompDef = oBOMRow.ComponentDefinitions.Item(1)
Dim oBOMRowDoc As Document
oBOMRowDoc = oCompDef.Document
Dim oFileName As String
oFileName = oBOMRowDoc.FullFileName
If oFileName.Contains("Content") Or oFileName.Contains("Standard parts") Then Continue For
StockNumber2 = oBOMRow.ComponentDefinitions(1).Document.PropertySets("Design Tracking Properties")("Stock Number").Value
PartNumber2 = oBOMRow.ComponentDefinitions(1).Document.PropertySets("Design Tracking Properties")("Part Number").Value
'MsgBox(oFileName)
If StockNumber2 = "" Then
MsgBox("Controleer dit onderdeel" & vbCrLf & "PartNumber: " & PartNumber2)
Exit sub
End If
If StockNumber2 = StockNumber And
StockNumber = "" Then
MessageBox.Show("LET OP!" & vbCrLf & "Sommige bestanden hebben geen Stocknumber" & PartNumber2 & vbCrLf &
"Optie 1: Laat de Titelblok rule lopen en probeer deze regel opnieuw" & vbCrLf &
"Optie 2, stap 1: Controleer de Bill of Materials op lege vakken bij het stocknumber (parts only tabblad)" & vbCrLf &
"Optie 2, stap 2: Als het een content center part is moet deze in de bibliotheek worden aangepast, meld dit bij Wouter!" & vbCrLf , "Lege waarde Stock Number")
Exit Sub
End If
PartNumber2 <> PartNumber Then
question1 = MessageBox.Show("LET OP!" & vbCrLf & "Tekeningnummer " & StockNumber2 & " dubbel gebruikt" & PartNumber & PartNumber2 & vbCrLf &
"Optie 2, stap 1: Verander het tekeningnummer van 1 van de parts met nummer " & StockNumber2 & vbCrLf &
"Optie 2, stap 2: Laat de Titelblok rule lopen" & vbCrLf & " " & vbCrLf & "WIL JE DE RULE BEEINDIGEN ?!", "Dubbele waarde Stock Number", MessageBoxButtons.YesNo, MessageBoxIcon.Error)
If question1 = vbYes Then
Exit Sub
Else If question1 = vbNo Then
MessageBox.Show("Rule loopt gewoon door", "LET OP !!",MessageBoxButtons.OK, MessageBoxIcon.Warning)
End If
End If
Else
Stockdeel1_1 = (Left(StockNumber2, (InStr(StockNumber2, "-")) -1))
Stockdeel2_1 = (Right(StockNumber2, (3)))
If Stockdeel1_1 = Stockdeel1 And Stockdeel2_1 = Stockdeel2 And
question2 = MessageBox.Show("LET OP!" & vbCrLf & "Tekeningnummer dubbel gebruikt met een ander revisie/versie nummer" & vbCrLf &
Stockdeel1 & " " & Stockdeel2 & " " & PartNumber & vbCrLf &
Stockdeel1_1 & " " & Stockdeel2_1 & " " & PartNumber2 & vbCrLf &
"Stap 1: Verander het tekeningnummer van het nieuwste part" & vbCrLf &
"Stap 2: Laat de Titelblok rule lopen" & vbCrLf & " " & vbCrLf & "WIL JE DE RULE BEEINDIGEN ?!", "Dubbele waarde Stock Number", MessageBoxButtons.YesNo, MessageBoxIcon.Error)
If question2 = vbYes Then
Exit Sub
Else If question2 = vbNo Then
End If
End If
End If
Next
End If
Next
'Updaten mass van assembly (door het accessen van de mass wordt hij ook geupdate)
mass = iProperties.Mass
'BOM Publisher
oDoc = ThisDoc.ModelDocument
If oDoc.DocumentType = kPartDocumentObject Then
MessageBox.Show("You need to be in an Assembly to Export a BOM", "Databar: iLogic - BOM Publisher")
Return
End If
oDoc = ThisApplication.ActiveDocument
'Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
'Options.Value("Author") = iProperties.Value("Summary", "Author")
'STRUCTURED BoM ===========================================================================
oBOM.ImportBOMCustomization("T:\01 ALGEMEEN\Inventor 2018\Templates\Bill of Materials.xml")
Try
' the structured view to 'all levels'
oBOM.StructuredViewFirstLevelOnly = False
Catch
MsgBox("Handmatig aanpassen van de kolommen en opslaan BOM")
End Try
' Make sure that the structured view is enabled.
oBOM.StructuredViewEnabled = True
Dim oStructuredBOMView As BOMView
oStructuredBOMView = oBOM.BOMViews.Item("Structured")
' Export the BOM view to an Excel file
oStructuredBOMView.Export(ThisDoc.Path + "\" + iProperties.Value("Project", "Stock Number") + ".xlsx", kMicrosoftExcelFormat, "BOM")
'PARTS ONLY================================================================================
'TECUMA BOM================================================================================
filename=iProperties.Value("Project", "Stock Number")
