MirrorFeature
MirrorFeature
MirrorFeature
I am trying to use the Mirror Feature function within Inventor 10. Does anyone have a small sample of code, in VB, showing this function working, in particular how to define the ParentFeatures as ObjectCollection?
Here is a sample that creates an extrude feature and then a mirror feature
using the extrude.
Sanjay-
Public Sub Mirror()
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
' Set a reference to the component definition.
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
' Create a new sketch on the X-Y work plane.
Dim oSketch As PlanarSketch
Set oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(3))
' Set a reference to the transient geometry object.
Dim oTransGeom As TransientGeometry
Set oTransGeom = ThisApplication.TransientGeometry
' Draw a rectangle
Dim oRectangleLines As SketchEntitiesEnumerator
Set oRectangleLines = oSketch.SketchLines.AddAsTwoPointRectangle( _
oTransGeom.CreatePoint2d(-1, 0), _
oTransGeom.CreatePoint2d(-4, -3))
' Create a profile.
Dim oProfile As Profile
Set oProfile = oSketch.Profiles.AddForSolid
' Create a base extrusion 1cm thick.
Dim oExtrude As ExtrudeFeature
Set oExtrude = oCompDef.Features.ExtrudeFeatures.AddByDistanceExtent( _
oProfile, 1, kNegativeExtentDirection,
kJoinOperation)
Dim oParentFeatures As ObjectCollection
Set oParentFeatures =
ThisApplication.TransientObjects.CreateObjectCollection
oParentFeatures.Add oExtrude
Dim oYZPlane As WorkPlane
Set oYZPlane = oCompDef.WorkPlanes.Item(1)
Dim oMirror As MirrorFeature
Set oMirror = oCompDef.Features.MirrorFeatures.Add(oParentFeatures,
oYZPlane)
End Sub
wrote in message news:5012205@discussion.autodesk.com...
Thanks Sanjay. I still have a problem in that I wish to Mirror the entire model.
I wish to have code that achieves the equivalent of the interative commands:
'Mirror Feature'
'Mirror the Entire Solid'
'Remove Original'
'Mirror Plane' & selecting the YZ Plane from the Origin
Hoping that you can help
Alistair
I've modified the code to mirror the solid instead of the extrude feature.
Also, the original is not retained by setting the 3rd argument of
MirrorFeatures.Add to True.
Sanjay-
Public Sub Mirror()
' Draw a rectangle
' Create a profile.
oProfile, 1, kNegativeExtentDirection, kJoinOperation)
oParentFeatures.Add oCompDef.SurfaceBodies.Item(1)
oYZPlane, True)
End Sub
wrote in message news:5015857@discussion.autodesk.com...
model.
'Mirror Feature'
'Remove Original'
Alistair
Thanks Sanjay,
Worked a treat. If only the API helpfiles could include such useful information.
Alistair
Isn't this forum the API helpfile? 😉
LOL
T. Ham
Mechanical Engineer
CDS Engineering BV
Dual Pentium XEON 2.2 Ghz
2 GB SDRAM
NVIDIA QUADRO4 700 XGL (Driver = 77.18)
18 GB SEAGATE SCSI Hard Disc
3Com Gigabit NIC
Windows 2000 Professional SP4
Autodesk Inventor Series 9 SP4
Autodesk Inventor Series 10 SP2
wrote in message news:5017197@discussion.autodesk.com...
Thanks Sanjay,
information.
Alistair
