MiniToolbar's EnableApply property not working
Ivan_Sinicyn
Message 1 of 1
Ivan_Sinicyn
I have a problem with the MiniToolbar in Inventor API. When I set MiniToolbar.EnableApply = False, the Apply button remains fully enabled - it doesn't visually change to a disabled state and can still be clicked by the user. This is different from the OK button, which properly disables (grays out and becomes unclickable) when I set EnableOK = False.
Here's my test log showing the issue:
14:01:00: Initial state: EnableOK = False, EnableApply = False
14:01:01: After selection: Bodies = 1, EnableOK = True, EnableApply = True
14:01:02: Apply button clicked: Bodies = 1, EnableApply before = True
14:01:03: After Apply and reset: EnableOK = False, EnableApply = False
14:01:03: After view update: EnableOK = False, EnableApply = False
14:01:27: Apply button clicked: Bodies = 0, EnableApply before = False
Note that at 14:01:03, I set EnableApply = False, but at 14:01:27 the Apply button was still clickable. When I check the property value it correctly returns False, but the button's visual state and functionality don't change at all.
Is it a bug?
iLogic:
Sub Main()
    oApp = ThisApplication
    oLog = ""
    isRunning = True
    ' Check if a part document is open
    If Not TypeOf oApp.ActiveDocument Is PartDocument Then
        MessageBox.Show("Please open a part document")
        Exit Sub
    End If
    oPartDoc = oApp.ActiveDocument
    ' Create InteractionEvents
    oInteractionEvents = oApp.CommandManager.CreateInteractionEvents
    oInteractionEvents.Name = "MiniToolbar Test"
    ' Setup SelectEvents
    oSelectEvents = oInteractionEvents.SelectEvents
    oSelectEvents.AddSelectionFilter(SelectionFilterEnum.kPartBodyFilter)
    oSelectEvents.Enabled = True
    ' Set up event handlers
    AddHandler oSelectEvents.OnSelect, AddressOf OnSelect
    AddHandler oSelectEvents.OnUnSelect, AddressOf OnUnSelect
    ' Create MiniToolbar
    oMiniToolbar = oInteractionEvents.CreateMiniToolbar()
    oMiniToolbar.ShowOK = True
    oMiniToolbar.ShowApply = True
    oMiniToolbar.ShowCancel = True
    ' Disable buttons by default
    oMiniToolbar.EnableOK = False
    oMiniToolbar.EnableApply = False
    WriteLog("Initial state: EnableOK = " & oMiniToolbar.EnableOK & ", EnableApply = " & oMiniToolbar.EnableApply)
    ' Add info label
    oMiniToolbar.Controls.AddLabel("InfoLabel", "Bodies selected: 0", "Information")
    ' Set toolbar position
    Dim oPoint As Point2d = oApp.TransientGeometry.CreatePoint2d(100, 100)
    oMiniToolbar.Position = oPoint
    ' Set up button handlers
    AddHandler oMiniToolbar.OnOK, AddressOf OnOK
    AddHandler oMiniToolbar.OnApply, AddressOf OnApply
    AddHandler oMiniToolbar.OnCancel, AddressOf OnCancel
    oMiniToolbar.Visible = True
    ' Start interactive events
    oInteractionEvents.Start()
    WriteLog("Events started")
    ' Main loop
    Do While isRunning
        oApp.UserInterfaceManager.DoEvents()
    Loop
    ' Cleanup
    Cleanup()
    ' Show full log at the end
    MessageBox.Show(oLog, "MiniToolbar Test Log")
End Sub
' Global variables
Public oApp As Inventor.Application
Public oPartDoc As PartDocument
Public oInteractionEvents As InteractionEvents
Public oSelectEvents As SelectEvents
Public oMiniToolbar As MiniToolbar
Public oLog As String
Public isRunning As Boolean
' Logging function
Sub WriteLog(message As String)
    oLog = oLog & message & vbCrLf
    ' Create or open log file
    Dim logPath As String = "C:\Temp\MiniToolbarTest.log"
    Dim fileStream As System.IO.StreamWriter
    Try
        fileStream = New System.IO.StreamWriter(logPath, True)
        fileStream.WriteLine(DateTime.Now.ToString() & ": " & message)
        fileStream.Close()
    Catch ex As Exception
        MessageBox.Show("Log writing error: " & ex.Message)
    End Try
End Sub
' OnSelect event handler
Sub OnSelect(JustSelectedEntities As ObjectsEnumerator, SelectionDevice As SelectionDeviceEnum, _
            ModelPosition As Inventor.Point, ViewPosition As Point2d, View As Inventor.View)
    Dim count As Integer = oSelectEvents.SelectedEntities.Count
    ' Update label with selected bodies count
    Dim oLabel As MiniToolbarControl = oMiniToolbar.Controls("InfoLabel")
    oLabel.DisplayName = "Bodies selected: " & count
    ' Enable/disable buttons
    oMiniToolbar.EnableOK = (count > 0)
    oMiniToolbar.EnableApply = (count > 0)
    WriteLog("After selection: Bodies = " & count & ", EnableOK = " & oMiniToolbar.EnableOK & ", EnableApply = " & oMiniToolbar.EnableApply)
    oApp.ActiveView.Update()
End Sub
' OnUnSelect event handler
Sub OnUnSelect(UnselectedEntities As ObjectsEnumerator, SelectionDevice As SelectionDeviceEnum, _
    WriteLog("After unselection: Bodies = " & count & ", EnableOK = " & oMiniToolbar.EnableOK & ", EnableApply = " & oMiniToolbar.EnableApply)
End Sub
' OK button handler
Sub OnOK()
    WriteLog("OK button clicked: Bodies = " & oSelectEvents.SelectedEntities.Count)
    isRunning = False
End Sub
' Apply button handler
Sub OnApply()
    WriteLog("Apply button clicked: Bodies = " & oSelectEvents.SelectedEntities.Count & ", EnableApply before = " & oMiniToolbar.EnableApply)
    ' Process selected bodies (just show a message in this test)
    MessageBox.Show("Processed bodies: " & oSelectEvents.SelectedEntities.Count)
    ' Reset selection
    oSelectEvents.ResetSelections()
    ' Force disable buttons and check their state
    WriteLog("After Apply and reset: EnableOK = " & oMiniToolbar.EnableOK & ", EnableApply = " & oMiniToolbar.EnableApply)
    ' Update label
    oLabel.DisplayName = "Bodies selected: 0"
    ' Check button state after update
    WriteLog("After view update: EnableOK = " & oMiniToolbar.EnableOK & ", EnableApply = " & oMiniToolbar.EnableApply)
End Sub
' Cancel button handler
Sub OnCancel()
    WriteLog("Cancel button clicked")
    isRunning = False
End Sub
' Resource cleanup
Sub Cleanup()
    If oSelectEvents IsNot Nothing Then
        RemoveHandler oSelectEvents.OnSelect, AddressOf OnSelect
        RemoveHandler oSelectEvents.OnUnSelect, AddressOf OnUnSelect
        oSelectEvents.Enabled = False
    End If
    If oMiniToolbar IsNot Nothing Then
        RemoveHandler oMiniToolbar.OnOK, AddressOf OnOK
        RemoveHandler oMiniToolbar.OnApply, AddressOf OnApply
        RemoveHandler oMiniToolbar.OnCancel, AddressOf OnCancel
        oMiniToolbar.Visible = False
    End If
    If oInteractionEvents IsNot Nothing Then
        oInteractionEvents.Stop()
    End If
End Sub
INV 2025.3
Replies (0)
