Minimum bounding box using convex hull
I am dealing with a 3D model that has over 50,000 components and I want to find out dimensions of all these components. I can get rangeboxes of all components pretty easilty but they are not correct. As these components are not aligned to x,y,z. All components are modelled in a way that their co-ordinate systems will match with global one when assembled.
I checked modmymachine blog and found something similar but that too doesn't find box for parts that are completely randomly oriented. https://modthemachine.typepad.com/my_weblog/2017/06/getting-the-overall-size-of-parts.html and their comment is giving me anxiety
The ability to automatically calculate a bounding box that is oriented to get the tightest fitting box possible is a very difficult problem that I haven’t seen a solution to. It’s something you could probably write a PhD paper on.
Some additional info about components: They are all cuboids with minor modifications here and there (slots, holes, tapers etc) can't share models due to confidentiality issues.
I googled this problem a bit and found that this can be achieved with reasonable accuracy using convex hull. Has anybody ever tried this before?
https://en.wikipedia.org/wiki/Minimum_bounding_box#Arbitrarily_oriented_minimum_bounding_box
There exist matlab implementations for this, but I'd still need to get extreme point/vertices from inventor. I don't think implementing the algorithm in VBa would be easy task at all.
YuhanZhang
This was also discussed in below post:
https://forums.autodesk.com/t5/inventor-ideas/minimum-bounding-box-of-non-aligned-parts/idi-p/802045...
We also have a user story(INVGEN-18008) for this, if you can provide a business case for this I can append the info to the user story.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
