minimal distance in file name
michielXWZ7U
michielXWZ7U
Hi guys, i am using this wonderfull code to export my file to a .dxf. my files are generated in the format 'material'-Thickness (measured for the default sheet metal style)'-1x-'part name'
'check that the active document is an assembly file
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
        MessageBox.Show("This Rule " & iLogicVb.RuleName & " only works on Assembly Files.", "WRONG DOCUMENT TYPE",MessageBoxButtons.OK,MessageBoxIcon.Error)
        Return
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'get user input
RUsure = MessageBox.Show ( _
"" _
& vbLf & "Zorg ervoor dat je bestand is opgeslagen." _
& vbLf & " " _
& vbLf & "zorg ervoor dat je materiaal is toegevoegd?" _
& vbLf & "even geduld a.u.b.", "iLogic - Export Sheet Metal ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
oPath = ThisDoc.Path
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'get DXF target folder path
oFolderDXF = oPath & "\" & "DXF Files" & "\" & oAsmName
oFolderSTEP = oPath & "\" & "STEP Files" & "\" & oAsmName
'- - - - - - - - - - - - -Component - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models
'this expects that the model has been saved
For Each oRefDoc In oRefDocs
iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
'check that model is saved
If(System.IO.File.Exists(iptPathName)) Then
Dim oDrawDoc As PartDocument
oDrawDoc = ThisApplication.Documents.Open(iptPathName, True)
oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName))
Try
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDrawDoc.ComponentDefinition
If oCompDef.Bends.Count = 0 Then
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolderDXF) Then
System.IO.Directory.CreateDirectory(oFolderDXF)
'Set the DXF target file name
oThickness = oRefDoc.ComponentDefinition.thickness.expression
oMaterial = oRefDoc.ComponentDefinition.material.name
oDataMedium.FileName = oFolderDXF & "\" & oMaterial & " - " & oThickness & " - 1 stuk - " & oFileName & ".dxf"
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Else
oCompDef.FlatPattern.Edit
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0&InvisibleLayers=IV_TANGENT;IV_ARC_CENTERS;IV_BEND;IV_BEND_UP;IV_BEND_DOWN;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_TOOL_CENTER_UP;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_UP;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL"
oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
oCompDef.FlatPattern.ExitEdit
Catch
End Try
Try
If oCompDef.Bends.Count > 0 Then
'Check for the STEP folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolderSTEP) Then
System.IO.Directory.CreateDirectory(oFolderSTEP)
'Set the step target file name
oDataMedium.FileName = oFolderSTEP & "\" & oMaterial & " - " & oThickness & " - 1 stuk - " & oFileName & ".stp"
oDrawDoc.SaveAs(oFolderSTEP & "\" & oMaterial & " - " & oThickness & " - 1 stuk - " & oFileName & (".stp") , True)
Catch
End Try
oDrawDoc.Close
Next
 Now i have this wonderful code to measure the minimal distance of a part
Dim Thickness As Double  = MinOfMany(Measure.ExtentsLength, Measure.ExtentsWidth, Measure.ExtentsHeight)
I would like to adjust the first code so that the .dxf files are saved in the format 'material' - 'thickness (measured in the format of the second formula' - 1x - part name
With kind regards,
Michiel
JelteDeJong
does this work for you:
        Return
'get user input
"" _
& vbLf & " " _
Return
Else
Try
oThickness = MinOfMany(Measure.ExtentsLength, Measure.ExtentsWidth, Measure.ExtentsHeight)
oCompDef.Unfold
Else
Dim sOut As String
Catch
End Try
Try
Catch
End Try
oDrawDoc.Close
Next
Jelte de Jong
Blog: hjalte.nl - github.com
