Attempting to change the colour of a part based on a perimeter
emilda.chiuye
emilda.chiuye
Hello
I have a number of tubes(part) with varying wall thicknesses of which I would like the colour of the tubes to change based on the thickness(perimeter), so the range of wall thicknesses and colours are as follows :
3.5-6.4mm should be red,
6.5-9.4mm should be yellow,
9.5-12.5mm should be Green and finally any wall thickness less than 3.5 should be grey in colour.
With the help of google I managed to find a solution and tweaked it a bit to suit my situation.
In my head it all makes sense but unfortunately Inventor disagrees, it returns with a massive syntax error!
I have pasted the error and the rule below.
Please kindly assist me.
If WALL_THICKNESS >= 9.5 Then
Feature.Color("Tube A") = "RED"
And If WALL_THICKNESS <= 12.5 Then
If WALL_THICKNESS >= 6.5 Then
Feature.Color("Tube A") = "YELLOW"
And If WALL_THICKNESS <= 9.4 Then
If WALL_THICKNESS >= 3.5 Then
Feature.Color("Tube A") = "GREEN"
And If WALL_THICKNESS <= 6.4 Then
If WALL_THICKNESS < 3.5 Then
Feature.Color("Tube A") = "GREY"
JelteDeJong
Try this and make sure the colour names exist in your part
If (WALL_THICKNESS < 3.5) Then
ElseIf (3.5 <= WALL_THICKNESS And WALL_THICKNESS <= 6.4) Then
ElseIf (6.5 <= WALL_THICKNESS And WALL_THICKNESS <= 9.4) Then
ElseIf (9.5 <= WALL_THICKNESS And WALL_THICKNESS <= 12.5) Then
Jelte de Jong
Blog: hjalte.nl - github.com
emilda.chiuye
Thank you so much!
Works 👍Perrrfectly 😀
