migration problem from inventor 2024 to 2025 (ODBC connection)
Marco_PeronXTBPH
Marco_PeronXTBPH
I recently updated inventor from version 2024 to 2025 and launching the exact same rule in the 2024 version everything works without a hitch, however in the 2025 version several errors appear and I am therefore unable to execute the same rule with the same conditions.
in the main rule the situation is more or less the following:
AddReference "System.Data"
AddVbFile "...\mServer.vb"	' Modulo per la gestione della connessione al DBOracle
Class ThisRule
   Sub main()
       mDataBase.Logger = Logger
       If Scarica_Dati_Da_Database(queryFile) = False Then Exit Sub
   End Sub
   Function Scarica_Dati_Da_Database(queryLoc As String) As Boolean
        Try
            Dim Query As String = My.Computer.FileSystem.ReadAllText(queryLoc)
            Query = Query.Replace("{LISTA}", lista)
            Logger.Trace(" apro connessione server")
            mDataBase.Connessione(connString)
            arrayConf = mDataBase.QueryArray(Query)
            mDataBase.ChiudiConnessione()
            connString = Nothing
            Query = Nothing
            Return True
        Catch ex As Exception
            Return False
        End Try
    End Function
End Class
the problem lies in the mServer.vb 'module' or at least given the inventor's errors this is what I think
this is the complete module that I wrote last year and which in the inventor 2024 version never gave me any kind of problem:
' <IsStraightVb>True</IsStraightVb>
Imports System.Data.Odbc
Imports System.Data
Public Module mDataBase
	Public property Logger As Autodesk.iLogic.Interfaces.IRuleLogger 'nel programma main richiamante aggiungere il seguente codice: mManSerr.Logger = Logger
    Private connection As OdbcConnection
	''' <summary>
	''' Connessione al server tramite modulo ODBC
	''' </summary>
	Public Sub Connessione(ByVal connString As String)
	    Logger.Trace("**Classe cDataBase - Public Sub Connessione")
	    Try
	        connection = New OdbcConnection(connString)
	        ' Imposta un timeout per la connessione (ad esempio, 10 secondi)
	        connection.ConnectionTimeout = 10
	        connection.Open()
	        Logger.Info(" Connessione aperta")
	        Logger.Error(" Connessione al server fallita: " & ex.Message)
	    End Try
	End Sub
	''' <summary>
	''' Riporta il risultato di una query in un DataTable.
	''' </summary>
	''' <param name="queryString"></param>
	''' Query da inviare al server.
	''' <returns></returns>
    Public Function QueryDataTable(ByVal queryString As String) As DataTable
        Logger.Trace("**Classe cDataBase - Public Function QueryDataTable")
        Dim dataTable As New DataTable()
        Try
            Dim command As New OdbcCommand(queryString, connection)
            Dim dataAdapter As New OdbcDataAdapter(command)
            dataAdapter.Fill(dataTable)
            Logger.Debug(" DataTable compilata")
            Logger.Error(" Errore durante l'esecuzione della query: " & ex.Message)
        End Try
        Return dataTable
    End Function
	''' <summary>
	''' Riporta il risultato di una query in un Array a due dimensioni.
	''' </summary>
    Public Function QueryArray(ByVal queryString As String) As Object(,)
        Logger.Trace("**Classe cDataBase - Public Function QueryArray")
        Dim result As Object(,) = Nothing
        Try
            Dim reader As OdbcDataReader = command.ExecuteReader()
            Dim columnCount As Integer = reader.FieldCount
            Dim resultList As New List(Of List(Of Object))
            ' Aggiunta dei nomi delle colonne nella prima lista
            Dim columnNames As New List(Of Object)
            For i As Integer = 0 To columnCount - 1
                columnNames.Add(reader.GetName(i))
            Next
            resultList.Add(columnNames)
            ' Popolamento della lista con i dati della tabella
            While reader.Read()
                Dim row As New List(Of Object)
                    row.Add(reader(i).ToString())
                Next
                resultList.Add(row)
            End While
            reader.Close()
            ' Conversione della lista di liste in un array bidimensionale
            Dim rowCount As Integer = resultList.Count
            result = New Object(rowCount - 1, columnCount - 1) {}
            For i As Integer = 0 To rowCount - 1
                Dim row As List(Of Object) = resultList(i)
                For j As Integer = 0 To columnCount - 1
                    result(i, j) = row(j)
                Next
            Next
            Logger.Debug(" Limiti righe tabDataBase - Minimo: " & LBound(result, 1) & " Massimo: " & UBound(result, 1))
            Logger.Debug(" Limiti colonne tabDataBase - Minimo: " & LBound(result, 2) & " Massimo: " & UBound(result, 2))
        End Try
        Return result
    End Function
	''' <summary>
	''' Chiude connessione al server.
	''' </summary>
    Public Sub ChiudiConnessione()
        Logger.Trace("**Classe cDataBase - Public Sub ChiudiConnessione")
        Try
            If connection IsNot Nothing AndAlso connection.State = ConnectionState.Open Then
                connection.Close()
                connection.Dispose()
                Logger.Info(" Connessione chiusa")
            End If
            Logger.Error(" Errore durante la chiusura della connessione: " & ex.Message)
        End Try
    End Sub
End Module
the errors I receive are the following:
The type 'OdbcConnection' is not defined.
The type 'OdbcCommand' is not defined.
The type 'OdbcDataAdapter' is not defined.
The type 'OdbcDataReader' is not defined.
any ideas on what the problem could be? (I'll start by saying that I currently have both versions of Inventor 2024/2025 installed, I don't know if this could create any problems but as already said several times, everything works without any problem in Inventor 2024)
Michael.Navara
The main reason is the Inventor 2025 uses .NET8 as runtime. In my opinion ODBC is not a core part of .NET8 anymore. You can get and reference the missing libraries from external sources like NuGET
Marco_PeronXTBPH
Perfect, I downloaded the file you linked, extracted the .dll and added the reference to it, now everything works again.
But now I have a similar problem with:
Imports System.Runtime.InteropServices
Dim inventorApp As Application = Nothing
inventorApp = Marshal.GetActiveObject("Inventor.Application")
It appears that GetActiveObject is no longer part of Marshal
Michael.Navara
