Migrating from iLogic to VB.Net - open idw in Inventor
Hello
I have a file path - trying to open the file (using VB.Net)!
The code below is from Youtube & a message box will display a column of filepaths & models.
Problems start after adding lines 79, 80 & mainly 89 - just trying to open the drawing just to see it (still testing).
How does VB.Net know to use Inventor to open the file?
The next stage will be to swap out the model on the drawing with the open in the list - code already supplied in VBA.
My guess is VBA & iLogic already know where Inventor is but Visual Studio (VB.Net) needs some instruction.
(Currently thinking this could just run as an .exe - not need to jump though the add-in hoops just yet.)
Imports Microsoft.Office.Interop
Imports Excel = Microsoft.Office.Interop.Excel
Imports Inventor
Imports System.Runtime.InteropServices
Imports System.Reflection
Imports System.Diagnostics
Public Class Form1
Dim _InvApp As Inventor.Application
Dim drawingFilename As String
Private Structure ExcelRows
Dim C1 As String
Dim C2 As String
End Structure
Private ExcelRowList As List(Of ExcelRows) = New List(Of ExcelRows)
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
Me.OpenFileDialog1.FileName = Nothing
If Me.OpenFileDialog1.ShowDialog = Windows.Forms.DialogResult.OK Then
Me.TextBox1.Text = Me.OpenFileDialog1.FileName
If GetInfo() = True Then
For Each Xitem In ExcelRowList
Dim lvitem As ListViewItem
lvitem = Me.ListView1.Items.Add(Xitem.C1)
lvitem.SubItems.AddRange(New String() {Xitem.C2})
Next
End Sub
Private Function GetInfo() As Boolean
Dim Completed As Boolean = False
Dim MyExcel As New Excel.Application
MyExcel.Workbooks.Open(Me.TextBox1.Text)
'extract
MyExcel.Sheets("sheet1").activate()
MyExcel.Range("A1").Activate()
Dim ThisRow As New ExcelRows
Do
If MyExcel.ActiveCell.Value > Nothing Or MyExcel.ActiveCell.Text > Nothing Then
ThisRow.C1 = MyExcel.ActiveCell.Value
MyExcel.ActiveCell.Offset(0, 1).Activate()
ThisRow.C2 = MyExcel.ActiveCell.Value
ExcelRowList.Add(ThisRow)
MyExcel.ActiveCell.Offset(1, -2).Activate()
Else
Completed = True
Exit Do
Loop
'close
MyExcel.Workbooks.Close()
MyExcel = Nothing
Return Completed
End Function
Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
Dim oIDW As Inventor.Application = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
'Dim oIDW As Inventor.Document
For i = 0 To ListView1.Items.Count - 1
'Do stuff
MsgBox(ListView1.Items(i).ToString)
MsgBox(ListView1.Items(i).SubItems(1).ToString)
' Find if the dwg exists.
oIDW = oIDW.Documents.Open(ListView1.Items(i).ToString)
Next
End Sub
End Class
Regards
Andrew
