Migrating from iLogic to VB.Net - open idw in Inventor
andrew_canfield
andrew_canfield
Hello
I have a file path - trying to open the file (using VB.Net)!
The code below is from Youtube & a message box will display a column of filepaths & models.
Problems start after adding lines 79, 80 & mainly 89 - just trying to open the drawing just to see it (still testing).
How does VB.Net know to use Inventor to open the file?
The next stage will be to swap out the model on the drawing with the open in the list - code already supplied in VBA.
My guess is VBA & iLogic already know where Inventor is but Visual Studio (VB.Net) needs some instruction.
(Currently thinking this could just run as an .exe - not need to jump though the add-in hoops just yet.)
Imports Microsoft.Office.Interop
Imports Excel = Microsoft.Office.Interop.Excel
Imports Inventor
Imports System.Runtime.InteropServices
Imports System.Reflection
Imports System.Diagnostics
Public Class Form1
    Dim _InvApp As Inventor.Application
    Dim drawingFilename As String
    Private Structure ExcelRows
        Dim C1 As String
        Dim C2 As String
    End Structure
    Private ExcelRowList As List(Of ExcelRows) = New List(Of ExcelRows)
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Me.OpenFileDialog1.FileName = Nothing
        If Me.OpenFileDialog1.ShowDialog = Windows.Forms.DialogResult.OK Then
            Me.TextBox1.Text = Me.OpenFileDialog1.FileName
        End If
        If GetInfo() = True Then
            For Each Xitem In ExcelRowList
                Dim lvitem As ListViewItem
                lvitem = Me.ListView1.Items.Add(Xitem.C1)
                lvitem.SubItems.AddRange(New String() {Xitem.C2})
            Next
        End If
    End Sub
    Private Function GetInfo() As Boolean
        Dim Completed As Boolean = False
        Dim MyExcel As New Excel.Application
        MyExcel.Workbooks.Open(Me.TextBox1.Text)
        'extract
        MyExcel.Sheets("sheet1").activate()
        MyExcel.Range("A1").Activate()
        Dim ThisRow As New ExcelRows
        Do
            If MyExcel.ActiveCell.Value > Nothing Or MyExcel.ActiveCell.Text > Nothing Then
                ThisRow.C1 = MyExcel.ActiveCell.Value
                MyExcel.ActiveCell.Offset(0, 1).Activate()
                ThisRow.C2 = MyExcel.ActiveCell.Value
                ExcelRowList.Add(ThisRow)
                MyExcel.ActiveCell.Offset(1, -2).Activate()
            Else
                Completed = True
                Exit Do
            End If
        Loop
        'close
        MyExcel.Workbooks.Close()
        MyExcel = Nothing
        Return Completed
    End Function
    Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
        Dim oIDW As Inventor.Application = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        'Dim oIDW As Inventor.Document
        For i = 0 To ListView1.Items.Count - 1
            'Do stuff
            MsgBox(ListView1.Items(i).ToString)
            MsgBox(ListView1.Items(i).SubItems(1).ToString)
            ' Find if the dwg exists.
            oIDW = oIDW.Documents.Open(ListView1.Items(i).ToString)
        Next
    End Sub
End Class
Regards
Andrew
mfoster9TD82
I'm assuming you're talking about using this for an external .exe or an addin rather that an iLogic or macro.
With what you have there, you are looking for an open instance of Inventor with
Dim application as Inventor.Application = ...GetActiveObject("Inventor.Application")
that is your "ThisApplication" that you are used to using.
Then you'll also need to define a Document that you will open the file as with
Dim document as Inventor.Document = application.Documents.Open(...)
From there is pretty much the same as iLogic.
There is more info about it in the API Overviews section in the Inventor API Help documentation included in the SDK tools
