Merging two rules
Merging two rules
Merging two rules
Hi to all,
I have two rules. One writes the material name in the user's iProperties and the other writes the stock number in the "Stock number" iProperties. Both take information from the materials database. I need to merge these two rules to run at the same time.
The first rule
Dim oDoc As PartDocument = ThisDoc.Document
iProperties.Value("Custom", "Materiál") = oDoc.ActiveMaterial.DisplayName
 The second rule
If ThisApplication.ActiveDocumentType <> kPartDocumentObject Then Exit Sub
oPartDoc = ThisApplication.ActiveDocument
Dim oMat As Asset
oMat = oPartDoc.ActiveMaterial
iProperties.Value("Project", "Stock number") = oMat.Item("physmat_Comments").Value
JelteDeJong
is this what you are looking for:
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kPartDocumentObject Then Exit Sub
Dim oMat As Asset = oDoc.ActiveMaterial
iProperties.Value("Custom", "Material") = oDoc.ActiveMaterial.DisplayName
Jelte de Jong
Blog: hjalte.nl - github.com
Hello and thank you. I already understand why it didn't work for me.
