Merging PDFs using iLogic
Message 1 of 26
Using iLogic, I am cycling through a user defined-folder of idws to update their title blocks and borders, update a few iProperties from a user-defined Excel file, and printing a PDF of the whole drawing.
What I would like to do is create a master PDF that I could append each created PDF print to.
Is this even possible through iLogic?  If so, how would I approach this?
Thank you,
Brian Daley...
Replies (25)
Message 21 of 26
emanuel.c
Hi @NachoShaw thank you for the info. Yes I saw it was a NET Framework issue and made sure NET 8 is installed (which may have been along with the update). But ya, it still has the issues.
Unfortunately, I do not have experience creating wrappers... Will have to dig in a little more, if time permits.
Thanks!
Message 22 of 26
g.georgiades
I am assuming you are using Process.Start somewhere. In .net, you have to use a wrapper to launch a non-executable. See this post.
https://forums.autodesk.com/t5/inventor-programming-ilogic/fail-to-use-process-start-in-inventor-202...
Message 23 of 26
emanuel.c
Thanks @g.georgiades!
I think adding the AddReference "System.Private.Uri" and installing NET 8 framework fixed it.
Thanks so much!
Message 24 of 26
Terry_N
Hi
Just thought I would upload the version I'm using that works with 2025 for people that come across this. I export my PDFs into a sub folder and always run this rule from the first drawing of the set which contains a drawing register so I've added a bit to name the PDF using the drawing register DWG iProperties for the file name and to also save the mergred PDF in the PDF folder.
AddReference "C:\Users\Public\global references\itextsharp.dll"
AddReference "System.IO"
'This rule requires a itextsharp.dll file to be at the local in line one.
Sub Main()
	'set the path of the folder contaiing all of the pdfs
	Dim _Path As String  = ThisDoc.Path &"\PDF Folder"
	'set the name of the new pdf you want to create without the extension
	Dim _Name As String = ThisDoc.FileName'
	'Set revision
	Dim _Rev As String = ThisDoc.Document.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
	'get the result, it will be either the path of the PDF or FALSE
	Dim MakePDF As New MergePDF(_Path, _Name, _Rev)
	'get the PDF result
	Dim OpenPDF As String = MakePDF.GetPDF
	'open on condition to the result
	Select Case OpenPDF
		Case "FALSE"
				MsgBox("No PDF was generated",MessageBoxIcon.Error,"Error")
		Case Else
			Process.Start(New ProcessStartInfo(OpenPDF) With {.UseShellExecute = True })
	End Select
End Sub
Public Class MergePDF
#Region "PRIVATE PROPERTIES"
    Private Property _Folder_Path As String = String.Empty
    Private Property _PDF_Name As String = Nothing
    Private Property _GetPDF As String = String.Empty
#End Region
#Region "FRIEND PROPERTIES THAT YOU CALL BACK"
    Friend Property GetPDF As String
        Set(value As String)
            _GetPDF = value
        End Set
        Get
            Return _GetPDF
        End Get
    End Property
#End Region
#Region "CONSTRUCTORS"
    Public Sub New(ByVal _folderpath As String, ByVal _pdfname As String, ByVal _Rev As String)
        'set the pdf Folder path
        _Folder_Path = _folderpath
        'set the pdf name
        _PDF_Name = _pdfname
			 _PDF_Name =_PDF_Name & "_" & _Rev & "_Set.pdf"
        'create the PDF and set the path
        _GetPDF = CreatePDF(_Folder_Path)
    End Sub
#End Region
#Region "HELPERS"
    Private Function CreatePDF(ByVal sFolderPath) As String
        Dim bOutputfileAlreadyExists As Boolean = False
        Dim sOutFilePath As String = IO.Path.Combine(sFolderPath, _PDF_Name)
        'sdet up return for a successful pdf. ret changes to FALSE if any errors occur for qualifying purposes
        Dim ret As String = sOutFilePath
        If IO.File.Exists(sOutFilePath) Then
            Try
                IO.File.Delete(sOutFilePath)
            Catch ex As Exception
                bOutputfileAlreadyExists = True
            End Try
        Dim iPageCount As Integer = GetPageCount(sFolderPath)
        If iPageCount > 0 And bOutputfileAlreadyExists = False Then
            Dim oFiles As String() = IO.Directory.GetFiles(sFolderPath)
            Dim oPdfDoc As New iTextSharp.text.Document()
            Dim oPdfWriter As iTextSharp.text.pdf.PdfWriter = iTextSharp.text.pdf.PdfWriter.GetInstance(oPdfDoc, New IO.FileStream(sOutFilePath, IO.FileMode.Create))
            oPdfDoc.Open()
            System.Array.Sort(Of String)(oFiles)
            For i As Integer = 0 To oFiles.Length - 1
                Dim sFromFilePath As String = oFiles(i)
                Dim oFileInfo As New IO.FileInfo(sFromFilePath)
                Dim sFileType As String = "PDF"
                Dim sExt As String = PadExt(oFileInfo.Extension)
                Try
                    AddPdf(sFromFilePath, oPdfDoc, oPdfWriter)
                    ret = "FALSE"
                End Try
            Next
            Try
                oPdfDoc.Close()
                oPdfWriter.Close()
                Try
                Catch ex2 As Exception
                End Try
            End Try
        Dim oFolders As String() = IO.Directory.GetDirectories(sFolderPath)
        For i As Integer = 0 To oFolders.Length - 1
            Dim sChildFolder As String = oFolders(i)
            Dim iPos As Integer = sChildFolder.LastIndexOf("\")
            Dim sFolderName As String = sChildFolder.Substring(iPos + 1)
            CreatePDF(sChildFolder)
        Next
        Return ret
    End Function
    Private Sub AddPdf(ByVal sInFilePath As String, ByRef oPdfDoc As iTextSharp.text.Document, ByRef oPdfWriter As iTextSharp.text.pdf.PdfWriter)
        Dim oDirectContent As iTextSharp.text.pdf.PdfContentByte = oPdfWriter.DirectContent
        Dim oPdfReader As iTextSharp.text.pdf.PdfReader = New iTextSharp.text.pdf.PdfReader(sInFilePath)
        Dim iNumberOfPages As Integer = oPdfReader.NumberOfPages
        Dim iPage As Integer = 0
        Do While (iPage < iNumberOfPages)
            iPage += 1
            oPdfDoc.SetPageSize(oPdfReader.GetPageSizeWithRotation(iPage))
            oPdfDoc.NewPage()
            Dim oPdfImportedPage As iTextSharp.text.pdf.PdfImportedPage = oPdfWriter.GetImportedPage(oPdfReader, iPage)
            Dim iRotation As Integer = oPdfReader.GetPageRotation(iPage)
            If (iRotation = 90) Or (iRotation = 270) Then
                oDirectContent.AddTemplate(oPdfImportedPage, 0, -1.0F, 1.0F, 0, 0, oPdfReader.GetPageSizeWithRotation(iPage).Height)
            Else
                oDirectContent.AddTemplate(oPdfImportedPage, 1.0F, 0, 0, 1.0F, 0, 0)
        Loop
    End Sub
    Private Function PadExt(ByVal s As String) As String
        s = UCase(s)
        If s.Length > 3 Then
            s = s.Substring(1, 3)
        Return s
    End Function
   Private Function GetPageCount(ByVal sFolderPath As String) As Integer
        Dim iRet As Integer = 0
            iRet += 1
        Next
        Return iRet
    End Function
#End Region
End Class
Message 25 of 26
Terry_N
well it was working last week. It's now returning False on OpenPDF even though it does successfully merge them so it prompts that it didn't work. I don't know enough to fix that.
Message 26 of 26
machiel.veldkamp
https://forums.autodesk.com/t5/inventor-programming-ilogic/sharing-combine-multiple-pdf-s-into-one-p...
___________________________
