Measuring Tool - Automatically Default To "All Decimals"
MartinMachinery
MartinMachinery
Employees at our company have to switch to "all decimals" in the measuring tool many times per day, which is an annoying setting that Autodesk has failed to implement for years, including the 2017 release. I wrote a macro that automates the "all decimals" process. If you copy and paste this code into a new module, then make a hotkey or add a button on the assembly/part/drawing ribbons for the "AllDecimals" subroutine, it will launch the measure tool and automatically switch your measure tool to "all decimals". I used direct window messages for the most robust possible command processing. There are no "SendKeys" in this program.
My PC setup is 64 bit Windows 7 Professional, Intel i7 3.5GHz, 32GB RAM
Disclaimer: this code is largely untested by anyone other than myself. It may contain errors, programming mistakes, hinder performance, or any other potential negative effect, though I have not personally experienced these issues. It is likely not full of best programming practices and contains snippets of code from many other sources. I have not commented the code to explain the processes. I did not want to spend time on anything other than simply developing a usable program (primarily for myself and others at my company). There is essentially no error handling. Proceed at your own risk.
Public Type DWORDAsLong
lLong As Long
End Type
Public Type DWORDAsInts
iLow As Integer
iHigh As Integer
End Type
Public Const WM_COMMAND = 273
Public Const WM_GETTEXT = 13
Public Const WM_GETTEXTLENGTH = 14
Public Declare PtrSafe Function FindWindow Lib "user32.dll" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
Public Declare PtrSafe Function FindWindowEx Lib "user32.dll" Alias "FindWindowExA" (ByVal Phwnd As Long, ByVal Nhwnd As Long, ByVal lpszClass As String, ByVal lpszName As String) As Long
Public Declare PtrSafe Function GetNextWindow Lib "user32" Alias "GetWindow" (ByVal hWnd As Long, ByVal wFlag As Long) As Long
Public Declare PtrSafe Function GetWindowText Lib "user32" Alias "GetWindowTextA" (ByVal hWnd As Long, ByVal lpString As String, ByVal cch As Long) As Long
Public Declare PtrSafe Function GetWindowTextLength Lib "user32" Alias "GetWindowTextLengthA" (ByVal hWnd As Long) As Long
Public Declare PtrSafe Function PostMessage Lib "user32" Alias "PostMessageA" (ByVal hWnd As Long, ByVal wMsg As Long, ByVal wParam As Long, lparam As Any) As Long
Public Declare PtrSafe Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hWnd As Long, ByVal wMsg As Long, ByVal wParam As Long, lparam As Any) As Long
Public Declare PtrSafe Function GetDesktopWindow Lib "user32" () As Long
Public Declare PtrSafe Function GetWindow Lib "user32" (ByVal hWnd As Long, ByVal wCmd As Long) As Long
Sub AllDecimals()
Dim TboxTxt As String
Dim BHwnd As Long
Dim TboxHwnd As Long
Dim wParam1 As Long
Dim MPhwnd As Long
MPhwnd = FindTool
If MPhwnd = 0 Then
InventorName = FindWindowLike(GetDesktopWindow(), "Inventor", "")
wParam2 = MAKEWPARAM(&H73C9, &H0)
SendMessage InventorName, WM_COMMAND, wParam2, Null
CopyTxt = False
Do While MPhwnd = 0
MPhwnd = FindTool
If MPhwnd <> 0 Then Exit Do
num = num + 1
If num >= 1000 Then
Exit Sub
MsgBox "Measuring Tool Not Found"
Loop
wParam1 = MAKEWPARAM(&H87A2, &H0)
PostMessage MPhwnd, WM_COMMAND, wParam1, Null
End Sub
Public Function MAKEWPARAM(ByVal wLow As Integer, ByVal wHigh As Integer) As Long
Dim t1 As DWORDAsInts
Dim t2 As DWORDAsLong
t1.iLow = wLow
t1.iHigh = wHigh
LSet t2 = t1
MAKEWPARAM = t2.lLong
End Function
Public Function getNameFromHwnd(ByVal hWnd As Long) As String
Dim title As String * 255
Dim tLen As Long
tLen = GetWindowTextLength(hWnd)
If tLen = 0 Then
getNameFromHwnd = "No Value Available"
Exit Function
GetWindowText hWnd, title, 255
getNameFromHwnd = Left(title, tLen)
End Function
Function FindTool()
Dim Phwnd As Long
Phwnd = FindWindow("#32770", "Measure Distance")
If Phwnd = 0 Then Phwnd = FindWindow("#32770", "Length")
If Phwnd = 0 Then Phwnd = FindWindow("#32770", "Position")
If Phwnd = 0 Then Phwnd = FindWindow("#32770", "Minimum Distance")
If Phwnd = 0 Then Phwnd = FindWindow("#32770", "Diameter")
FindTool = Phwnd
End Function
Sub API_Window()
Dim ClassName$, SearchName$, WinName$
ClassName = ""
SearchName = "Inventor"
WinName = FindWindowLike(GetDesktopWindow(), SearchName, ClassName)
SendMessage WinName, WM_COMMAND, wParam2, Null
End Sub
Function FindWindowLike(hWndParent As Long, Caption As String, ClassName As String) As String
Dim hWnd&
Const GW_HWNDNEXT = 2, GW_CHILD = 5
hWnd = GetWindow(hWndParent, GW_CHILD)
Do Until hWnd = 0
If WindowText(hWnd) Like "*" & Caption & "*" Then
FindWindowLike = hWnd
Exit Do
hWnd = GetWindow(hWnd, GW_HWNDNEXT)
Loop
End Function
Function WindowText(hWnd As Long) As String
Dim lng&, str$
Const WM_GETTEXT = &HD, WM_GETTEXTLENGTH = &HE
If hWnd <> 0 Then
lng = SendMessage(hWnd, WM_GETTEXTLENGTH, 0&, 0&) + 1
If lng > 0 Then
str = String$(lng, vbNullChar)
lng = SendMessage(hWnd, WM_GETTEXT, lng, ByVal str)
If lng > 0 Then WindowText = Left$(str, lng)
End Function
dg2405
Well done! I've testet it with IV2014
If somebody has the german language you have to replace the following lines:
with
If Phwnd = 0 Then Phwnd = FindWindow("#32770", "Länge")
If Phwnd = 0 Then Phwnd = FindWindow("#32770", "Mindestabstand")
If Phwnd = 0 Then Phwnd = FindWindow("#32770", "Durchmesser")
@MartinMachinery,
I also have this issue with the decimals not defaulting to all.  I got the code to work in the VBA Editor, but I could not get it to work using a hot key.  Could you explain step by step how you managed to get it to work.
John Cellini
Mechanical Designer
Atlas Hydraulics
MartinMachinery
To make a button:
Open any assembly. Right click on a blank area of the ribbon --> Customize User Commands --> Ensure you are in the "Ribbon" tab --> click the drop down menu under "Choose Commands From:" --> select "Macros" --> select "All Decimals" --> check under "Choose tab to add custom panel to:" and make sure you are adding the button to the desired panel --> click the ">>" button to move it over into the assemble menu --> If desired, check the "Large" and "Text" options --> Click "Apply"
*note: you will need to repeat this process with different panels if you want to add the button to more panels than just the assemble tab.
To add the command to a hotkey:
Right click on a blank area of the ribbon --> Customize User Commands --> Go to the "Keyboard" tab --> click the drop down menu under "Categories" --> select "Macros" --> In the "Keys" column, assign a hotkey by clicking in the column to the left of the "AllDecimals" macro (I assigned J as the hotkey) --> Click "Apply" and then "Close"
When I go through those steps, so some reason I cannot find the "Alldecimals" macro under the macro drop down. Do I need to load it somewhere for the macro to show up in the custom menu.
@MartinMachinery
I got it to work, thanks for your quick response, that has been a pet peeve of mind since I started using Inventor
John Cellini
Mechanical Designer
Atlas Hydraulics
