Measure distance between faces with attributes in a Assembly, problem????
Message 1 of 10
HI everyone!
Hi have a assembly with several sub-assemblys , the sub-assemblys contain a assembly called a "Suporte rolos sup".
for example:
subassembly 1
 - subassembly 1
 - Suporte rolos sup
subassembly 2
 - Suporte rolos sup
 - subassembly 2
the assembly  "Suporte rolos sup", has a attribute in a face.
so for every assembly  "Suporte rolos sup" in the main assembly , i want to measure the distance between the face that has that attribute.
I'm trying to do that with the code bellow but the following error:
-run time error '5'
-invalide procedure,call or argument
  is displayed in the line" Distance = ThisApplication.MeasureTools.GetMinimumDistance(oface1, oface2)"
 Option explicit
Dim oface1 As Face
Dim oface2 As Face
Private Sub calc_esp_entre_estacoes()
Dim odoc As Inventor.Document
Set odoc = ThisApplication.ActiveDocument
Dim odoc_ass As Inventor.AssemblyDocument
If odoc.DocumentType = kAssemblyDocumentObject Then
    Set odoc_ass = odoc
Else
    MsgBox "O documento is not a assembly"
    Exit Sub
    For i = 1 To odoc_ass.ComponentDefinition.Occurrences.Count
        Dim Pos
        Pos = InStr(odoc_ass.ComponentDefinition.Occurrences(i).Name, "Suporte rolos sup")
        If Pos <> 0 Then
            Dim odoc_atrib As Inventor.Document
            Set odoc_atrib = odoc_ass.ComponentDefinition.Occurrences(i).Definition.Document
                Call GetAttributeUsingManager(odoc_atrib)
        If odoc_ass.ComponentDefinition.Occurrences(i).DefinitionDocumentType = kAssemblyDocumentObject Then
            Call subocc(odoc_ass.ComponentDefinition.Occurrences(i).Definition.Document)
    Next i
End Sub
Public Sub subocc(odoc As Inventor.AssemblyDocument)
    Dim i As Integer
    Dim Pos
    Dim subdoc As Inventor.AssemblyDocument
    For i = 1 To odoc.ComponentDefinition.Occurrences.Count
        Pos = InStr(odoc.ComponentDefinition.Occurrences(i).Name, "Suporte rolos sup")
        If Pos <> 0 Then
            Set odoc_atrib = odoc.ComponentDefinition.Occurrences(i).Definition.Document
        If odoc.ComponentDefinition.Occurrences(i).DefinitionDocumentType = kAssemblyDocumentObject Then
            Set subdoc = odoc.ComponentDefinition.Occurrences(i).Definition.Document
            Call subocc(subdoc)
    Next i
End Sub
Public Sub GetAttributeUsingManager(doc As Inventor.Document)
    ' Get the active document.  It can be any type of document.
    'Dim doc As Document
    'Set doc = ThisApplication.ActiveDocument
    ' Get the attribute manager.
    Dim attribMgr As AttributeManager
    Set attribMgr = doc.AttributeManager
    ' Find all attribute sets named "SampleSet".
    Dim foundEntities As ObjectCollection
    Set foundEntities = attribMgr.FindObjects("SampleSet")
    If foundEntities.Count <> 0 Then
    Dim foundEntity As Object
    For Each foundEntity In foundEntities
        If TypeOf foundEntity Is Face Then
            If oface1 Is Nothing Then
                Set oface1 = foundEntity
                Exit For
            If Not (oface1 Is Nothing) Then Set oface2 = foundEntity
        ElseIf TypeOf foundEntity Is Edge Then
    Next
    If (Not (oface1 Is Nothing)) And (Not (oface2 Is Nothing)) Then
    Dim Distance As Double
    Distance = doc.UnitsOfMeasure.ConvertUnits(Distance, "cm", "mm")
    ListBox3.AddItem (Distance)
    Set oface1 = Nothing
    Set oface2 = Nothing
End Sub
Replies (9)
Message 2 of 10
sanjay.ramaswamy
Since you are doing this in the context of an assembly, the inputs to the GetMinimumDistance need to be FaceProxy objects instead of Face objects. Look into programming help overview that discuss the concept of proxies.
Message 3 of 10
Hi Sanjay!
and thanks for your answer and time , but i'm a little bit confused with this proxyies, after reading the little help overview article , i dont know in what way do i have to change my code to get the desired results, what do i have to change??, do i will have to use component definiton and component occurrence? if yes i will have to use component defintion and ocurrences, how can i get wich occurence has the selected attribute?
can i get a reference to the subassembly face that has the attributes?
I would like to have more information about this proxyies , because i'm new to this.
Thanks a lot for your help
Message 4 of 10
sanjay.ramaswamy
My mistake. I looked at your code again and it looks like you intend to measure the distance between faces on the same part. In which case, you don't need to worry about proxies. However, it seems like the logic in the following piece of your code is not quite right. When I removed the 'Exit For' statement, I was able to get it to work. You may want to re-check the logic.
                Exit For
Next
Message 5 of 10
Hi again Sanjay!
hell i have changed the following code, has you said, but i get the same error.
de variable count is a global variable.
Can you be more clear of what is missing here.
thanks a lot for your help.
                If count = 0 Then
                             count = 1
                   ElseIf count = 1 Then
                        count = 2
        Next
    If count = 2 Then
Message 6 of 10
sanjay.ramaswamy
Since count seems to be a global variable, are you making sure to initialize it to 0 before every run? I put that in, and with that change, your new logic seems to work fine for me and correctly returns the distance.
Message 7 of 10
Hi Sanjay!
Again i have changed the code and nothing, i get the same error display, are you sure that you have your code running?
Can you send the code you have ?so i can see what is going wrong here?
Thanks a lot.
If foundEntities.count <> 0 Then
                If count = 0 Then
                             count = 1
                        count = 2
        Next
    If count = 2 Then
    count = 0
Message 8 of 10
sanjay.ramaswamy
Yes, I have the code working in Inventor 2011. I've changed the names of the occurrence and the attribute set to match my dataset - you'll need to change those back. I've highlighted the changes that I made in red.
Option Explicit
Dim oface1 As Face
Dim oface2 As Face
Dim count As Long
count = 0
    Set odoc_ass = odoc
Else
    Exit Sub
    Dim i As Long
    For i = 1 To odoc_ass.ComponentDefinition.Occurrences.count
        Dim Pos
        Pos = InStr(odoc_ass.ComponentDefinition.Occurrences(i).Name, "block")
        If Pos <> 0 Then
    Next i
End Sub
    Dim i As Integer
    Dim Pos
    For i = 1 To odoc.ComponentDefinition.Occurrences.count
        Pos = InStr(odoc.ComponentDefinition.Occurrences(i).Name, "block")
        If Pos <> 0 Then
            Call subocc(subdoc)
    Next i
End Sub
    Set foundEntities = attribMgr.FindObjects("AttribTest")
                If count = 0 Then
                             count = 1
                        count = 2
        Next
    If count = 2 Then
    MsgBox "Distance = " & Distance & " mm"
    'ListBox3.AddItem (Distance)
End Sub
Message 9 of 10
hello sanjay,
  how to get minimum distance from a face to point using vba??
if face is oFace and point is pnt???
Dim dD As Double
Dim oFace as Face
Dim pnt as workpoint
   dD = ThisApplication.MeasureTools.GetMinimumDistance(oFace(1), pnt.Point)
  debug.Print dD
Thanks in advance for you reply.
Amool.
Message 10 of 10
adam.nagy
Autodesk Support
Autodesk Support
From your description it's not obvious what the problem is. There is an issue in your code but I don't know if it's just a typo in the pasted code or that is the actual issue you are experienceing.
If oFace is of type Face, then oFace(1) is an invalid expression since oFace is not an array.
Adam Nagy
Autodesk Platform Services
