How many holes in a part?
Message 1 of 11
I'm looking to find how many holes there are in a part ( and then what their diameters are).
I tried using
Dim oPartDoc As Document
Set oPartDoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
MsgBox "there are " & oCompDef.Features.HoleFeatures.Count & " holes"
but this falls down if a hole feature created more than one hole at the same time.
I'm open to suggestions for some better code.
Replies (10)
Message 2 of 11
sanjay.ramaswamy
The HoleFeature.HoleCenterPoints property can be used to determine exactly how many holes a hole feature defines. However, this approach won't cover for cases where other features (such as an extruded cut) resulted in holes. If you want your approach to be a generic one, you'd be better off analyzing the part for "holes" rather than relying on feature counts. One method is to look for all interior cylindrical faces (i.e. hollow cylindrical faces). There's a sample in programming help (titled "Check if cylindrical face is interior or exterior") that demonstrates this. There are other topology-based feature recognition techniques as well that you can use to find holes in a part.
Message 3 of 11
Thanks for the guidance Sanjay
Message 4 of 11
Sorry Sanjay, but I need you to elaborate a bit more on how to use HoleCenterPoints.
I'm a bit stumped at the moment !
Message 5 of 11
sanjay.ramaswamy
The count of items in the collection returned by the HoleCenterPoints property indicates the number of holes. The collection contains (2d) SketchPoint objects for hole centers defined by sketch points, and (3d) Point objects for all other hole definitions.
Message 6 of 11
Sanjay,
I give up, could you post me a snippit of code showing how to get the HoleCenterPoints collection as while I understand what needs to be done, even reading the programming help files several times I can't achieve it  Man Sad
Maybe they should have sent me on the advanced training which covered macro's.  It was included in the package when we bought Inventor but subsequently forgotten about!
Message 7 of 11
sanjay.ramaswamy
If all you care about is the count of holes defined by hole features, try this...
Sub HoleCount()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As PartComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Dim lHoleFeatureCount As Long
    lHoleFeatureCount = oDef.Features.HoleFeatures.Count
    Dim lHoleCount As Long
    lHoleCount = 0
    Dim oHoleFeature As HoleFeature
    For Each oHoleFeature In oDef.Features.HoleFeatures
        lHoleCount = lHoleCount + oHoleFeature.HoleCenterPoints.Count
    Next
    MsgBox "There are " & lHoleFeatureCount & " hole features and " & _
       lHoleCount & " holes in the part."
End Sub
Message 8 of 11
Thank you for the code Sanjay.
I have a little problem trying to learn for the future.  I have printed out the IV API Object Model for reference when looking for how I might code something.  Using this I can go Part Document - PartComponentDefinition - PartFeatures - HoleFeatures -  HoleFeature -      but at this point I get lost as I don't see HoleCenterPoints on the printout  ??
How should I proceed in future?
Message 9 of 11
sanjay.ramaswamy
I prefer to use the VBA object browser...
Message 10 of 11
Hy, although this is an old thread, i have a question.
I tested the code and it works well, but. In my part i have created holes, by copying a hole feature, or mirroring etc.
these features and holes are not counted. Can you tell me how to count (and evaluate) those holes?
Thanks Bodo
Message 11 of 11
perrysc
I know I'm necroposting but here's the solution.
Function _GetHoleCountAndDiameters(oPartDoc As PartDocument) As Double(,)
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	Dim oTO As TransientObjects = ThisApplication.TransientObjects
	Dim oPartDef As PartComponentDefinition = oPartDoc.ComponentDefinition
	Dim oSizes As New List(Of Double)()
	Dim oLines As ObjectCollection = oTO.CreateObjectCollection
	Dim oTestLine As Line
	Dim oIsExisting As Boolean
	For Each oFace As Face In oPartDef.SurfaceBodies.Item(1).Faces
		If oFace.SurfaceType = 5891 Then
			oTestLine = oTG.CreateLine(oFace.Geometry.BasePoint,oFace.Geometry.AxisVector.AsVector)
			oIsExisting = False
			For Each oLine As Line In oLines
				If oLine.IsColinearTo(oTestLine) Then oIsExisting = True
			Next
			If Not oIsExisting Then
				oLines.Add(oTestLine)
				oSizes.Add(oFace.Geometry.Radius*2)
	Next
	Dim oUniqueSizeList As New List(Of Double)()
	For Each oSize As Double In oSizes
		If Not oUniqueSizeList.Contains(oSize) Then oUniqueSizeList.Add(oSize)
	Next
	oUniqueSizeList.Sort
	Dim oHoles(oUniqueSizeList.Count-1,1) As Double
	For i As Integer = 0 To oUniqueSizeList.Count-1
		oHoles(i,0) = oUniqueSizeList.Item(i)
		oHoles(i,1) = 0
	Next
		oHoles(oUniqueSizeList.IndexOf(oSize),1) = oHoles(oUniqueSizeList.IndexOf(oSize),1) + 1
	Next
	Return oHoles
End Function
