Measure dimensions of each part in an assembly using iLogic
devonsZN5MQ
devonsZN5MQ
Hi All
I'm relatively new to iLogic so please excuse if this question is trivial.
I am trying to write an ilogic code that:
- looks at an assembly,
- fetches all the parts in the assembly,
- measures their extent dimensions, and then
- groups them according to some condition (for example if max_extent/min_extent > 10 then MessageBox.Show("This is a plate"))
My current code only measures the extents of the full assembly, instead of each individual part, which is of no use to me.
Any help would be much appreciated, thanks!
' Get the active assembly.
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
' Get the assembly component definition.
Dim oAsmDef As AssemblyComponentDefinition
oAsmDef = oAsmDoc.ComponentDefinition
' Get all of the leaf occurrences of the assembly.
Dim oLeafOccs As ComponentOccurrencesEnumerator
oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
' Iterate through the occurrences and print the name.
Dim oOcc As ComponentOccurrence
For Each oOcc In oLeafOccs
	meas = Measure.ExtentsLength 'here is where I am having my problem
    MessageBox.Show(oOcc.Name & meas)
Next
theo.bot
