Cost Code for Top Levels
JamesMeBoi
JamesMeBoi
Here is some code that I got from the forum, is there anyone who knows how to make it desifer between and .IPT and .IAM, I am running into an issue when I give parts a cost, and then run the code in an assembly it will update the assemblies cost it will update by adding the two together and I end up with double the cost of the assembly.
Sub Main
    '- - - - - - - - - - - sum the custom iProperty - - - - - - - - - -
    'clear the custom property in the assembly
    iProperties.Value("Project", "estimated cost") = 0
    'set a reference to the assembly component definintion.
    'This assumes an assembly document is open.
    Dim oAsmCompDef As AssemblyComponentDefinition
    oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    'Iterate through all of the occurrences
    Dim oOccurrence As ComponentOccurrence
    For Each oOccurrence In oAsmCompDef.Occurrences
        Call ProcessAllChildren(oOccurrence)
    Next
    MessageBox.Show("Setting Estimated cost for top level assembly to: " & "$" & sumNumber, "Estimated cost")
    iProperties.Value("Project", "estimated cost") = Round (sumNumber,2)
End Sub
'Global
Private sumNumber As Double = 0
Public Sub ProcessAllChildren(ByRef oOccurrence As ComponentOccurrence)
      If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
        'property in the parts
        yNumber = iProperties.Value(oOccurrence.Name, "Project", "estimated cost")
		lnumber = iProperties.Value(oOccurrence.Name, "Custom", "Labor Cost")
        'MessageBox.Show("yNumber =  " & yNumber, oOccurrence.Name)
        sumNumber = sumNumber + yNumber + lnumber
        'MessageBox.Show("sumNumber =  " & sumNumber,"Running Total")
    Else
        'MessageBox.Show("This is a VirtualComponentDefinition",  oOccurrence.Name)
    Dim oCompOcc As ComponentOccurrence
    Dim oComponentSubOccurrences As ComponentOccurrences
    For Each oCompOcc In oOccurrence.SubOccurrences
        If oCompOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
           oComponentSubOccurrences = oCompOcc.SubOccurrences
           If Not oComponentSubOccurrences Is Nothing Then
            If oComponentSubOccurrences.Count > 0 Then
                ProcessAllChildren(oCompOcc)
        Else
     Next
End Sub
A.Acheson
 If oOccurrence.DefinitionDocumentType = kAssemblyDocumentObject Then
  MessageBox.Show("Is an assembly","Document check")
Elseif oOccurrence.DefinitionDocumentType =kPartDocumentObject Then
MessageBox.Show("Is a part","Document check")
Above is the if statements for detecting document type, the sub routine is actually using the assembly filter already to loop through sub assemblies.
Regards
Alan
