Measure cosmetic weld loop
- Mute
- Permalink
- Report
I'm trying to measure cosmetic welds in a weldment assembly in order to estimate welding time.
The code i've written works fine for edges and chains, but when it comes to loops i can't find anything useful for this purpose in the CosmeticWeld object.
My approach is to access every edge in the cosmeticweld, add it to a green highlight set (this is to confirm to the user that the weld is being measured) and measure the weld.
A cosmetic weld defined by the loop option however does not contain any edges?
Does anybody here have any suggestion on how to measure these welds?
This is the code i have today:
Imports Inventor
Imports System.Runtime.InteropServices
Public Class Form1
Dim ThisApplication = GetObject(, "Inventor.Application")
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
Dim HS As HighlightSet
Dim oUOM As UnitsOfMeasure
oUOM = ThisApplication.ActiveDocument.UnitsOfMeasure
HS = ThisApplication.ActiveDocument.CreateHighlightSet
HS.Color = ThisApplication.TransientObjects.CreateColor(0, 255, 0)
Dim ThisDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim weldCompDef As WeldmentComponentDefinition = ThisDoc.ComponentDefinition
Dim cosmeticWelds As CosmeticWelds = weldCompDef.Welds.CosmeticWelds
Dim cosmeticWeld As CosmeticWeld
Dim dTotLength As Double
dTotLength = 0
For Each cosmeticWeld In cosmeticWelds
Dim oEdge As Edge
Try
For Each oEdge In cosmeticWeld.Edges
HS.AddItem(oEdge)
Dim dMin As Double, dMax As Double
Call oEdge.Evaluator.GetParamExtents(dMin, dMax)
Dim dLength As Double
Call oEdge.Evaluator.GetLengthAtParam(dMin, dMax, dLength)
dTotLength = dTotLength + dLength
Next
Catch
'THIS IS WHERE I NEED HELP
MsgBox("Can't measure loops")
End Try
Next
MsgBox("Total Weld Length: " & oUOM.GetStringFromValue(dTotLength, UnitsTypeEnum.kMillimeterLengthUnits))
End Sub
End Class
Jhoel Forshav
Download my free Inventor Addin - Hole Projector
LinkedIn | Ideas | Contributions | Blog posts | Website
