Maximum string length?
Electrik
Electrik
I'm using iLogic to auto-save a PDF of an open file to a specific directory. I'm using string variables to piece together the new file path. That new string (as a variable) is 136 characters. It seems to be truncating my path to 119 characters. Does that sound right? Is there a limitation in place, or could I have something else going on?
Yes, I know that's a lot of characters. I'm trying to get that shortened in the first place.
My back-up plan is to create more, shorter strings to add together with "var1 & var2 & var3", etc...
Thanks!
Inventor Professional 2021
Vault Professional 2021
WCrihfield
Hi @Electrik.  According to Microsoft's own website for the String Class, "The maximum size of a String object in memory is 2-GB, or about 1 billion characters."  So, I don't think it is a limitation of the data type itself.  It is more likely a limitation of the computer system or server's file system.  There is definitely a set limit on how long a file path & name can be.  If you are using 'mapped drive' letters, you may be missing out on the true full file path, because the true path will go all the way up to the main file server.
Wesley Crihfield
(Not an Autodesk Employee)
Electrik
haha - 1 billion characters - yes, I  should be okay, there.
Thanks for the insight - it helps steer me to the next step in my diagnosis.
