Maximum distance between two EdgeLoops/Edges with API
patrick.kulenkampff
Message 1 of 1
patrick.kulenkampff
Hi Everyone,
I'm trying to get the maximum distance between two EdgeLoops or Edges with the API in Inventor. Currently I can get the minimum distance with MeasureTools.GetMinimumDistance () but I need the maximum distance too.
I saw a few post in which in cylindrical surface if you select manually the measure tool you can get the maximum distance but I didn't found anything for the API.
Regards!
Replies (0)
