matrix woes
matrix woes
matrix woes
Hi guys,
I have an assembly that contains a part and a hole feature (the hole feature is at the assembly level). Using the api, I'm trying to get the hole location relative to the part's coordinate system in a without using the holeplacementdefinition.distance property, this way I can get the hole location regardless of the way it was defined. Any help would be greatly appreciated.
Dominik
ekinsb
Below is some code that I believe will do what you want.  I've tried to comment it to explain what's going on.
Public Sub AssemblyHoleFeatureInPartSpace()
   Dim asmDoc As AssemblyDocument
   Set asmDoc = ThisApplication.ActiveDocument
   Dim hole As HoleFeature
   Set hole = ThisApplication.CommandManager.Pick( _
                                 kAssemblyFeatureFilter, _
"Select a hole feature.")
   ' A single hole feature can define multiple actual holes
   ' in a part
and the position of the holes can be defined
   ' in different ways, i.e.
at sketch points, distance from
   ' an edges, concentric to a circle, etc.  The
   ' HoleCenterPoints property returns the coordinate point
   ' for each physical hole created by the hole feature. The
   ' code below uses that to determine the hole position and
   ' then gets a cylinder from the hole to determine the
   ' direction.
   Dim holeCenter As Object
   For Each holeCenter In hole.HoleCenterPoints
      ' Center points can be returned as a sketch point when
      ' the hole was created using a sketch point, or a
      ' coordinate for other placement types.
      Dim holePosition As Point
      If TypeOf holeCenter Is SketchPoint Then
         Dim holeSketchPoint As SketchPoint
         Set holeSketchPoint = holeCenter
         Set holePosition = holeSketchPoint.Geometry3d
      Else
         Set holePosition = holeCenter
      ' Iterate through the occurrences the hole affects.
      Dim occ As ComponentOccurrence
      For Each occ In hole.Participants
         ' Get the transform from the occurrence.
         Dim occMatrix As Matrix
         Set occMatrix = occ.Transformation
         ' Invert the matrix to get an assembly to
         ' occurrence transform.
         occMatrix.Invert
         ' Transform the hole point into occurrence space.
         Dim newPoint As Point
         Set newPoint = holePosition.Copy
         Call newPoint.TransformBy(occMatrix)
         ' Display the coordinates.
         Debug.Print "Position in assembly space"
         Debug.Print ("   " & hole.name & " position in " _
                      & occ.name &
" is " & _
                      Format(holePosition.X, "0.000000") _
                      & "," & _
Format(holePosition.Y, "0.000000") _
                      & "," & _
Format(holePosition.Z, "0.000000"))
         Debug.Print "Position in part space"
         Debug.Print ("   " & hole.name & " position in " & _
                      occ.name &
" is " & _
                      Format(newPoint.X, "0.000000") _
                      & "," & _
                      Format(newPoint.Y, "0.000000") _
                      & "," & _
                      Format(newPoint.Z, "0.000000"))
      Next
   Next
End Sub
Brian Ekins
Mod the Machine blog
That's exactly what I wanted.  Thanks a bunch Brian !
