iLogic - Delete Feature
Requesting a code snippet that deletes a named feature(s) from a given part file.
jdkriek
Here's an iLogic and VBA solution 😉
iLogic:
oDoc = ThisDoc.Document
oFeatures = oDoc.ComponentDefinition.Features
Try
oFeatures("NameOfYourFeature").Delete
Catch
MsgBox("No feature exists with that name")
End Try
VBA: Could be shorter, but like the check on the name.
Public Sub RemoveFeature()
    Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
    Dim oFeature As PartFeature
    Dim oFeatures As PartFeatures
    Set oFeatures = oDoc.ComponentDefinition.Features
    For Each oFeature In oFeatures
        If oFeature.Name = "NameOfYourFeature" Then
            oFeature.Delete
    Next
End Sub
Hope this helps.
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Thank you kindly for the reply.
I should've deleted this topic a little while back as the exact same question was answered here:
http://forums.autodesk.com/t5/Autodesk-Inventor/Deleting-features-using-iLogic/m-p/3563592/highlight...
Accepting as a solution in the case someone searches this forum for the same topic.
jdkriek
I am sorry you needed to post in another forum to get an answer. Sometimes threads in this section get overlooked.
Jonathan D. Kriek
