Material Library | How to change Physical Asset Value unit
Message 1 of 1
I am trying to create a custom material library from third party materials. I could create library, add material and also change Physical Asset Property Values. But I want to set the values in a specified unit. How to do it?
This is how I set float asset value and it works. It is just i can't use the unit i want to set the value. pa is Physical Asset of the newly created material and propertyValue is a string containing float value.
Why i want to do it
I get the material data from some third party and they specify the unit for the values. So i want to specify the same unit as those received from third party.
Replies (0)
