Material change using Inventor API
Message 1 of 10
I changed the material using the vb.net code shown below.but after changing material the object is not updated ,the volume and mass didn't change ..why? any idea. here is my code
Dim oDoc As PartDocument
oDoc = inventorApp.ActiveDocument
Dim oDTProps As PropertySet
oDTProps = oDoc.PropertySets.Item("{32853F0F-3444-11d1-9E93-0060B03C1CA6}")
Dim oDesignerProp As Inventor.Property
oDesignerProp = oDTProps.ItemByPropId( _
PropertiesForDesignTrackingPropertiesEnum.kMaterialDesignTrackingProperties)
oDesignerProp = oDTProps.Item("Material")
oDesignerProp.Value = "Titanium"
oDoc.Update()
Replies (9)
Message 2 of 10
is it change the mass automatically when I change the material from api.?or any changes need to my code??
Message 3 of 10
jdkriek
You are only changing the iProp, that doesn't actually change the material
You need to use the ComponentDefinition like this:
oDoc.ComponentDefinition.Material.Name = "Titanium"
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 4 of 10
jdkriek
Actually, this may be the proper way to update everything, but still using ComponentDefinition
oDoc.ComponentDefinition.Material = oDoc.Materials.Item("Titanium")
Jonathan D. Kriek
Message 5 of 10
i tried this and it works but sometimes it takes awhile to update.
sometimes i have to go to the other open doc and back to see the updated material...
is there a code that can eliminate this delay update? or going back and forth to other open doc?
ive added doc.update but still no luck,.,,
inventor 2013
vault 2013
Message 6 of 10
jdkriek
iLogicVb.UpdateWhenDone = True
Jonathan D. Kriek
Message 7 of 10
im not using ilogic. im using vba.
Message 8 of 10
jdkriek
Indeed, sorry I forgot.
We are actually converting from VBA to External iLogic and VB.NET add-ins at work.
Jonathan D. Kriek
Message 9 of 10
Try this this will help me and working fine....just update the mass using this code  after changing the material.
Dim oPropSet As PropertySet
oPropSet = oPartDoc.PropertySets("Design Tracking Properties")
oPropSet.Item("Material").Value = DropDownList1.SelectedItem.Text
Dim materialDef As Material = oPartDoc.Materials(DropDownList1.SelectedItem.Text)
oPartDoc.ComponentDefinition.Material = materialDef
oPartDoc.Update()
Dim mass As Double = oPartDoc.ComponentDefinition.MassProperties.Mass
oPartDoc.SaveAs("F:\inventor\Proof Of Con\Cube\Cube_update1.ipt", True)
oPartDoc.SaveAs("F:\inventor\Proof Of Con\WebSite14\Documents\Cube_Update.ipt", True)
Message 10 of 10
what is the code for selecting something in the model explorer?
